Jeanneau Attalia - Page 21 - SailNet Community
 6Likes
post #201 of 277 Old 04-03-2014
JensK's Avatar
Re: Jeanneau Attalia
Dear Mark
Certainly an important problem. No bright ideas. I would use the Sherlock Homes looking glass: keep the floorboards off, cover the bilge with paper towel, go sailing, se where the water first comes in.
Best luck
Jens
JensK
Sailing in Denmark
Jeanneau Attalia
1986
31 feet
JensK is offline
post #202 of 277 Old 04-15-2014
Mark,
I don't know if you have solved your problem, but I've had the same symptom in our Attalia. I solved it by changing the prop shaft seal to as PSS-seal. I don't know if this is the cure for your problem, but good luck.
Jonas
Virgo is offline
post #203 of 277 Old 04-17-2014 Thread Starter
Not quite Senior Member
Waymar83's Avatar
Send a message via Yahoo to Waymar83
Thanks,
Have not been out for about two weeks so have not been able to investigate further.
Jonas, curious about the PSS-seal. was it complicated to install? (it looked easy in the video but that was done in a shop with new parts all round and not in the engine compartment.
Mark
Now based in Barbados.... and wait for it.....the boat is too!
Waymar - Jeanneau, Attalia
Waymar83 is offline
post #204 of 277 Old 04-19-2014
Hello Waymar,
It was quite easy to change to the PSS-seal. The problem was linked to the "great" space around the shaft. I hade to make a bigger hole in the wall between the engine compartment and the space behind (where I have my batteries). I did that for hand with a small tiger saw. Before that I had released the shaft from the engine and pushed it backward, to get more working space. (Check the end of the shaft to make sure there are no sharp edges - they can destroy the new seal.) With a bigger hole it was "just" to get down to it and mount the new seal, according to the instructions. I fixed the end of the venting in the starboard locker, to make sure it's over the water surface.
Take a look at the pictures and good luck!
Jonas
Virgo is offline
post #205 of 277 Old 04-28-2014
Backstay adjuster?
Hello,
I'm about to change my backstay adjuster from a mechanical type to an arrangement with cascade and a mainsheet system. I have a masthead rig. Does anyone else have the system I've explained above? I wonder how much force will occur in the system, which leads to how strong the equipment have to be. Any experience?
/Jonas
Virgo is offline
post #206 of 277 Old 05-08-2014
blt2ski's Avatar
Oh yeah, I know ALL ABOUT that vent for a pss shaft. I was the first one the shop did with a vent on a sail boat. Not a big deal while motoring. But first time we were sailing, my daughter went below, yells up, dad, is there supposed to be water above the floor boards?!?!?!?!
Oh sheet! so lots of bailing etc later, I figure out the vent is bringing water inside theboat. prop is moving.....so I vicegrip the end of the tube, problem solved temporarily any how. Later look at directions, and figure out the vent tube is to be ABOVE the waterline in a loop per say......opening was BELOW the water line! hmmmmmm no wonder it was siphoning into the bilge! Any way, "I" redid the vent tube, no issues with this since.
Altho a year ago, came back to boat after a few days, water again above the floor boards. See water coming in from the shaft seal. Pull boat, empty before and after pulling....... The carbon shaft seal had loosened over the years. Also again based on directions, figured out the intial installer, did not tighten the shaft seal as tight as directions call for, so when it went, it went.
not sure I would go with another pss, or go back to a packing gland, both are good, both bad.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #207 of 277 Old 09-08-2014
Question Rig and chainplate
Hello,
Im thinking about get a new pole and reinforce the chainplates.
1. Have anyone changed pole from masthead to partial(?) rig (7/8)? Whats your experience?
2. Have anyone reinforced the chainplates in your Attalia? How did you do?
/Jonas
Virgo is offline
post #208 of 277 Old 09-22-2014 Thread Starter
Waymar83's Avatar
Hi Virgo!
I have not reinforced the chainplates (yet). I'm not sure its necessary. Are you thinking of replacing your mast and putting in a fractional rig? What would be the advantage?
Mark
Waymar83 is offline
post #209 of 277 Old 09-25-2014
Hi Waymar,
Yes, I'm thinking about replacing my mast with at fractional rig. In the east coast of Sweden the average wind speed is around 7 knots. My opinion, according to that, is that we can have more sail on our Attalia in Sweden compare to an Attalia sailing for example the coast outside La Rochelle (14 knots). Ill meet "my" sailmaker tomorrow to discuss how much sail we can have, optimized to winds around 7 knots. Were doing good in winds around 23 knots, without any reefs and full genua (140%). But in our normal winds we have problems to hold speed (maybe it says more about me and not the boat ).
I think (hope) the advantage is a faster boat, better opportunities to trim and better to go high in the wind. I think there will be wrapped spreaders (correct name in english?) and therefore we can probably sheet the foresail closer to the centre line.
Another reason to change the mast is that its 30 year and nothing has been changed before. I'm afraid that the mast one day or another will get of the boat by itself with little help from the wind. That might ok during a race, but not when were out on a family trip.
/Jonas
Virgo is offline
post #210 of 277 Old 09-26-2014
blt2ski's Avatar
You may just need to replace the standing rigging itself. The mast itself should be ok.
For 7 knots of wind, you probably need a 155 that is made of some light cloth. IE something that will only work in winds to maybe 10 knots. Or a code 0 might be another option, as those are around 180% of your foretriangle area.
These two options would be my first ones.
Another to look at, locally 2 Arcadias have had mast dismastings, and that was due to the cabin top deck attachment point. THere is apparently wood under this part, and it rots, when it rots enough, it give way, the mast comes down. Mine is hsowing signs of this. Whether or not the Attalia has the same issue, I do not personally know. But worth looking at if you go as far as you are replacing things.
Another option frankly, if you are going to replace the rig, find a carbon setup from another boat about the same size. THen at least you lose some upper wt aloft going to a lighter stick, which should help the ballast a bit better in higher winds.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
Jeanneau quality is fine (Jeff H) JHodor Boat Review and Purchase Forum 4 12-28-2003 01:28 AM
Jeanneau Sun Odyssey 51 Pipes Boat Review and Purchase Forum 1 09-13-2002 06:48 AM
Jeanneau Sun Odyssey 40 DS mhofmann Boat Review and Purchase Forum 1 01-03-2002 02:10 AM
Jeanneau 45 davejean Boat Review and Purchase Forum 0 08-03-2001 05:55 AM
Jeanneau Tonic 23 dpcolohan Boat Review and Purchase Forum 0 03-11-2001 04:00 AM
HTML code is Off
