Go Back   SailNet Community > Boat Builders Row > Jeanneau
Old 02-28-2009
tooobx is on a distinguished road
Cost for Bottom Paint Job
I have a 45 foot sloop, two years old. Can anyone please tell me what a fair price is to have a boat yard redo the bottom with a good quality ablative paint. I purchased the boat new with an ablative paint on it already - quality unknown. I have no prior experience with boat yards and feel obviously helpless with every conversation. I learned the cost of the paint is about $200 +/- per gallon. But I can't find reliable information on what a yard would charge a knowledgeable owner. Thanks for any help offered.
Old 02-28-2009
ASA and PSIA Instructor
Depends on what you expect to be done. You don't want to paint the bottom unless it needs the paint, i.e. there isn't enough on already to last until the next haul. Less ablative paint is better than more. Your bottom may need:
1. No paint at all.
2. Touch up on low spots where a base coat is showing.
3. Touch up and one full coat.
4. If the existing paint is flaking off, strip the bottom to gelcoat or barrier coat, paint with one coat of base paint , then two coats of top paint. this is a very expensive job.
A two year old boat should not have too much paint on it, so you shouldn't need to strip paint. Touch up and one coat should be cheap, in boat terms, I would think $400-500 plus paint, although it's been 7-8 years since I had a yard paint my bottom. Again, don't paint unless you know you need it.
Old 02-28-2009
Thanks. That makes more sense than anything I've heard in two years. My local "caretaker" has had a diver clean the bottom every 3-4 months ($130 per dive); and now he's telling me it's going to be around $2,800 to quick haul and do the bottom. I've been a bit, maybe a lot, naive it seems, but I'm starting to question some of his sage advice.
Old 02-28-2009
CaptainForce's Avatar
I just paid $2,354 for a haul out; pressure wash; two coats of trinidad 75; changed cutlass bearing and shaft zinc; buff and wax entire freeboard; cosmetic fill and touch up four dings; and the name painted on my transom. This was for my 41' Morgan at a competitively priced North Florida yard. My cost would have been near a thousand less if it was just for the pressure wash and paint. I was quoted $1,500 for the pressure wash with one coat at a Virginia yard. I used to get a price about 25% less in the Bahamas at Man-o-War Cay and I get quotes about 25% higher from New Jersey to Mass. and then lower again in Maine.
Old 02-28-2009
I'm in the Annapolis MD area. Do you know how prices here compare to the other areas you mentions? Thanks for your input.
Old 02-28-2009
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
Tooobx,
My marina, last time I checked, was charging something like $10.00 per foot to sand lightly and one coat of paint. You supply the paint, they do the rest. This is not including the haul-out, pressure wash, block & tarp, which I think is about $6.00 per foot for non slip holders.
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Old 02-28-2009
FarCry's Avatar
Bombay Clipper
FarCry is on a distinguished road
My marina charges $12/ft to haul and launch plus $10/ft to prep and paint the bottom. Primer if needed is an additional $4/ft. Paint and primer not included.
Old 02-28-2009
mgmhead's Avatar
Somewhat Senior Member
mgmhead is on a distinguished road
Did you say you're in Annapoli$
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
Old 02-28-2009
I think the $1,500 Virginia quote would be similar in Maryland. I know that was about the rate I would have paid in Solomons. Aythya crew
Old 03-05-2009
Myblueheaven is on a distinguished road
bottom paint cost...final
So, what did you end up paying and for what specifically? Information is invaluble.
HTML code is Off
socialist money running out... Rockter Off Topic 17 2 Weeks Ago 02:25 AM
Can I put VC-17 over hard bottom paint? Finallybuyingaboat Gear & Maintenance 3 11-02-2008 10:42 PM
How much and what kind of bottom paint... MedSailor Gear & Maintenance 2 07-07-2008 08:12 PM
Bottom Paint Compatibility Dan Dickison Gear and Maintenance Articles 0 01-24-2001 07:00 PM
