Go Back   SailNet Community > Boat Builders Row > Jeanneau
Old 04-12-2009
Ian38 is on a distinguished road
Attalia problem
Hi I've just taken ownership of a 1986 Attalia. So far I'm very pleased with it appart from what appears to be a design problem. Does anyone else have a problem with water lying on the port side cockpit seat not draining away?
If so has anyone found a solution?
Old 04-12-2009
blt2ski's Avatar
Must be an issue with Jeanneau's of that era. My 85 Arcadia is that way, I also know of three other Arcadia's, with the same issue!
While I admit I am not an attalia, seems like a common problem for the 30 and 32' Jeanneaus from that time period.
marty
She drives me boat,
I drives me dinghy!
Old 04-12-2009
davester is on a distinguished road
congratulations on the new boat
My Attalia has the same issue. I never thought about doing anything about it, but I suppose one could drill a hole and install a hose that drains into the cockpit somewhere near the scupper. I think the hose could be behind the wood panel in the rear of the aft cabin, so it would be out of the way. It doesn't seem worth the trouble to me though, unless someone has a more simple solution.
dave
Jeanneau Attalia 32
Mystic, Ct
Old 05-03-2009
dave
Think I'll have to live with it, If I drilled a hole in the seat as far back as I could it would still appear in the aft cabin. The wooden panelling is further back that you think
Ian
HTML code is Off
Yanmar 2GMF starter solenoid mdemuth Gear & Maintenance 13 04-09-2008 12:12 PM
Visual basic problem... Rockter Off Topic 0 10-26-2007 07:24 AM
Universal diesel engine problem bcolton Gear & Maintenance 0 04-26-2006 01:50 PM
Head Problem bjoc2314 Gear & Maintenance 3 04-23-2003 09:16 AM
Engine Oil Pressure Problem msamelso Gear & Maintenance 2 02-20-2001 06:25 PM
