Zipper along length of sail - Page 2 - SailNet Community
post #11 of 17 Old 05-31-2013
overbored's Avatar
Re: Zipper along length of sail
Several small boats use a zipper luff on the jib which closes around the forestay with the halyard inside . my Prindle has one in the jib. and many racers used a zipper foot back in the late 60's into the 70's.
"GOLD RUSH" PRINDLE 16
overbored is offline
post #12 of 17 Old 05-31-2013
Originally Posted by FirstCandC View Post
.....It looked like it was down the leech.
If this is correct, it isn't the foot or luff.
Jeanneau 54DS
Minnewaska is offline
post #13 of 17 Old 02-07-2014 Thread Starter
Sorry to bring up an old thread, but Faster was right. After 5 months of putting my working jib through all kinds of sadistic abuse, I took it down for repair. This was just before a beautiful weekend with a strong southwest wind. You HAVE to go sailing here with a strong southwest wind, so I pulled the big genoa out, and sure enough it worked on the roller furler. I had to zip a few feet at a time while I fed the sail into the furler. The boat EATS miles on a beam reach with this sail.
HOWEVER, the sail blocks my view to the leeward side while the boat is heeled over. When I let off the jib sheet, I gain visibility but lose speed. How do you handle this situation?
ALSO, I have another sail that is much lighter (a 150/drifter?). This sail will not go in the groove of the furler, due to a large cable that runs the length of the luff with an eye at each end. Since I do not have a temporary stay, can I attach it to the furler at the two attachment points without sliding it in the groove? This would be in very light wind conditions only.
FirstCandC is offline
post #14 of 17 Old 02-07-2014
I don't discuss my member
zz4gta's Avatar
1. Look around the sail.
2. the light air sail is probably meant to be flown on it's wire luff, like a code zero.
Merit 25 # 764 "Audrey"
zz4gta is offline
The Following User Says Thank You to zz4gta For This Useful Post:
FirstCandC (02-07-2014)
post #15 of 17 Old 02-07-2014
no longer reading SailNet
Alex W's Avatar
That loose luff sail could be really useful. It would let you keep a reasonable sized jib on the furler (like a 110%) that can be used in moderate to high wind. In light air you can pull out the loose luff sail for close hauled to a beam reach (or deeper if you don't have a gennaker or spinnaker).
To use it well I think you'll want to have a very low stretch halyard for it, and a sheave that can handle the higher loads.
The only zippers on sails that I've heard of are for zipper luff sails on dinghies. It was interesting to see the larger discussion of those (I missed it the first time around).
Alex W is offline
The Following User Says Thank You to Alex W For This Useful Post:
post #16 of 17 Old 02-07-2014 Thread Starter
1- It is harder than it sounds. I guess I will keep trying.
post #17 of 17 Old 02-07-2014
Alex W's Avatar
I find it easier to look around a big genoa if I sit on the low side of the boat. On most boats our size it is also a lot easier to see the sail tell tales from that position. This is best done with the rest of the crew on the high side of the boat to balance you out.
I generally don't run huge deck sweeping sails when sailing solo, unless the wind is really light.
Alex W is offline
New Member looking for a Junior Zipper Sail stemthetide General Discussion (sailing related) 1 07-02-2012 05:07 PM
Main sail foot vs boom length Barquito Gear & Maintenance 8 12-15-2011 03:15 PM
zipper foot MDDesperado herSailNet 2 02-01-2004 10:35 AM
