Missing telltales... - SailNet Community
 2Likes
  • 1 Post By Minnewaska
  • 1 Post By Seaduction
post #1 of 6 Old 06-12-2013 Thread Starter
My mainsail is missing some telltales on it. Whats the best way to replace them, needle and some more florescent orange yarn?
Sent from my SAMSUNG-SGH-I717 using Tapatalk 4 Beta
BillA98272 is offline
post #2 of 6 Old 06-12-2013
Re: Missing telltales...
Sail tape.
flyingjib likes this.
Jeanneau 54DS
Minnewaska is offline
post #3 of 6 Old 06-12-2013
Seņor Member
PorFin's Avatar
+1 on the sail repair tape. Fast and easy.
Get a couple of pieces of telltale ribbon, and tape the forward end onto the main.
________
'85 BYB Vagabond 39
PorFin is offline
post #4 of 6 Old 06-13-2013
These work.
Sublime likes this.
Seaduction is offline
post #5 of 6 Old 06-14-2013
paulk's Avatar
Needle holes in some modern sail materials (not to call it cloth) might cause problems with delamination or tears. If it's not actually a cloth, but a sheet of plastic, perforating it might not be a good idea. Using a patch of ripstop or other tape to hold your yarn, thread, or whatever would probably be the easiest solution. If it is a cloth sail, it's probably so old and blown out that the telltales won't make any difference. Poking a hole in a cloth sail won't make that much difference either. It used to the the way to install your telltales.
paulk is offline
post #6 of 6 Old 07-20-2013
west marine has them really cheap ready to apply (red/green), otherwise: yarn, old cassette tape, ect and some adhesive sail tape works fine
I wouldn't suggest sewing them on just because it's more work and you can easily damage the sail
star..board..
XDLaser is offline
What's Missing?? I wish... What if? diverpam Cruising & Liveaboard Forum 13 11-20-2007 03:55 PM
Missing new threads and missing replys JakeLevi Announcements and Suggestions Box 8 06-27-2007 09:54 AM
telltales sailingforever Seamanship & Navigation 10 08-11-2006 04:59 PM
telltales Southie Learning to Sail 0 11-08-2005 01:00 PM
Telltales on a jib natejount Gear & Maintenance 3 06-09-2003 08:08 PM
