Spring lines and cleats - Page 2 - SailNet Community
 2Likes
post #11 of 21 Old 06-25-2013
first sailed january 2008
northoceanbeach's Avatar
Re: Spring lines and cleats
Do you have cleats near your winches for cleating off jib sheets? That's what I use or a loop around the winch.
northoceanbeach is offline
post #12 of 21 Old 06-25-2013
No. Purpose built cleats for docking/towing.
Goldfinger is offline
post #13 of 21 Old 06-25-2013
bljones's Avatar
Originally Posted by Dog Ship View Post
Until you get into the larger yachts, I have yet to see midship cleats.
Note midship cleat aft of upper shroud.
23'.
It's 5 o'clock somewhere:
bljones is offline
post #14 of 21 Old 06-25-2013
bljones's Avatar
Maybe it's just me, but i cringe when I see docklines looped around winches. winches are for sail management- they are not bollards.
bljones is offline
post #15 of 21 Old 06-25-2013 Thread Starter
Well being a newbie to sailing I appreciate all the help I can get... There are cleats just aft of the winches I can use those. As for the mid ship... I was rummaging through all the cubby and plastic bins and I found one of the loop. Made from brass that slides on the jib track so I guess I'm set.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
BillA98272 is offline
post #16 of 21 Old 06-25-2013 Thread Starter
Oh btw what is a chock?
post #17 of 21 Old 06-27-2013 Thread Starter
Nvr mind found chock in one of my beginner sailing books.
Sent from my Kindle Fire using Tapatalk 2
post #18 of 21 Old 06-27-2013
vtsailguy's Avatar
I have a mid ship cleat for a track you can have for $50
Three mini-pirates scour the Caribbean Seas with stops for ice cream and legos
Latest blog post:
vtsailguy is offline
post #19 of 21 Old 06-27-2013
Thanks Courtney.
I would have a much bigger issue with dock lines on shrouds, which are not b built for those kind of loads, than on winches, which are.
hunter Legend 37 Semper Paratus
Formerly - Tartan 34C Yawl
T34C is offline
post #20 of 21 Old 06-27-2013
I agree with the shrouds. However, winches are designed to take a load from a specific direction on a narrow plane. In fact, they usually must be angled, if the load is not going to be within that plane.
I suspect the shear strength of a winch works 99% of the time as a bollard, but not what they were designed to do and an extraordinarily expensive experiment.
Jeanneau 54DS
Minnewaska is offline
Controlling LinesóCleats, Clutches and Jammers sailingdog Gear & Maintenance 7 04-30-2009 07:19 PM
Spring Lines ---The Details? NCC320 Seamanship & Navigation 18 01-25-2009 09:13 PM
Blocks, cleats, and lines.... overwelming.. zz4gta Gear & Maintenance 10 10-22-2007 10:08 AM
Spring Lines Mark Matthews Seamanship Articles 0 08-06-2000 08:00 PM
Spring Lines Mark Matthews Gear and Maintenance Articles 0 08-06-2000 08:00 PM
