New sailing j-22 to a Hobie wave - Page 2 - SailNet Community
 7Likes
post #11 of 21 Old 07-10-2013
Re: New sailing j-22 to a Hobie wave
Some excellent advice on this this thread.
Most Hobies don't have a centerboard which is one of the reasons they can be tricky to tack. You hit the nail on the head when you said the Hobie seemed to take a wider track while tacking than did the J22. The 22 was turning on it's keel. Relatively speaking the difference is like the j boat turning on a dime.
That said, the advice to maintain speed, and not stall the rudders is spot on. Hobies need momentum to tack. Anything that bleeds speed off is a tack killer.
if you get stuck half way thru the tack depending on wind speed you may need to take a step or two to get going. Essentially, because the boat can't go forward because it is head to wind you need to go backwards. Huh? Yup, you need to sail backwards to get yourself unstuck ( out of Irons). In moderate to heavy winds this is a one step process - reverse the rudders. The wind pushes the boat backwards, the stern of the boat will go in whatever direction the rudders are pointing. The sail should be unsheeted until the bow comes around to your sailing course. Once pointed in the right direction go neutral on the rudders, sheet in and sail away. In light winds there is sometimes an extra step - that is - using the main sail to help you back up. Rather than just sitting there bobbing up and down waiting for physics to take over, give it some help by pushing the main sail out to act like a big air brake. Whatever wind there is will push you back more quickly by doing this. Experience Hobie racers who blow a tack make this look like part of the tacking sequence. IOW, with some practice, it's not hard to do.
Good luck with your sailing experience and welcome to a great sport!!!! Or is it a hobby? Either way, it's a lot of fun!!!!!
ottos likes this.
TJC45 is offline
post #12 of 21 Old 07-10-2013
Originally Posted by Sal Paradise View Post
My opinion...the sunfish sails more like a real boat. And it will go in the direction you want it to, within reason.
The Hobie is faster downwind or on a reach, but God help you if you have to go against the wind- then they are awful. I can never really get them to tack or go upwind. But they do have more room.
No disrepect meant here, but I gotta take exception to this. Hobies ARE real boats. They are more challenging to sail than the average monohull boat and require some extra skill set developement to sail efficiently. Once these skills are learned the boat is like any other boat, handling it comes naturally.
Besides being a blast to sail, Hobies are excellent teaching platforms. Take the H16 - While every H16 is identical, these boats are extremely adjustable. outhaul, downhaul, batten tension, jib tension, traveler, and mast rake all come into the tuning picture when setting the boat up for current conditions. Adding a full set of telltales lets student sailors see the effects of every adjustment and every input. Along with having alot of fun students who learn on Hobies, because they are more challenging, can step onto any monohull and sail it.
And again, no disrepect but I also disagree with these boats being awfull to sail upwind. In the right hands Hobies go to wind without issue. In many cases we can out point monohulls depending on conditions. And regardless, we will always beat them around the cans.
overbored, ChristinaM and domromer like this.
TJC45 is offline
The Following User Says Thank You to TJC45 For This Useful Post:
overbored (07-10-2013)
post #13 of 21 Old 07-10-2013
overbored's Avatar
thanks for that post. well said. I thought it was very interesting when the America's cup guys started to sail the CATs and I watched them make all the typical mistakes sailors make when learning a to sail a Cat.
TJC45 likes this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #14 of 21 Old 07-11-2013 Thread Starter
This response sorta leads into my next question. Beyond just enjoying myself on the water. I do have a goal/dream of getting a boat large enough to go on overnight trips with my wife and explore the gulf. With my budget it going to have to be a monohull. Can I continue using the wave and become a better sailor and have the skills to sail a larger monohull down the road, or should I be sailing more monohual dinghys? I really enjoy sailing the wave as it's so comfortable and easy to sail. But I also want to be moving in the right direction for my eventual goal.
I suppose in the winter I'll be sailing dinghys anyways as the wet ride of the cat won't be that much fun when the water is in the 50s. I just don't want to forget how to use a Jib entirely! Basically is it as easy jump from sailing a cat to a monohual? Do the skills crossover?
domromer is offline
post #15 of 21 Old 07-12-2013
overbored's Avatar
after you master any small dingy you will find almost any cruising boat easy to sail. but when it comes to docking you will have a bit more to learn. the saiing part is the easiest part of the cruising boat
TJC45 likes this.
post #16 of 21 Old 07-12-2013
Your experience sailing the Hobie is fully transferable to larger more complex boats. That the hobie is tougher to tack and that it doesn't have a jib will, if anything, make you a better sailor.
The fact that you are sailing a small highly responsive boat will make you a better sailor. You can see the effects of wind current waves etc on the boat. You get instant feedback to any input. That is something that doesn't happen on a larger boat.
The number of hulls has nothing to do with the actual learning to sail part of the program. When you transition to a monohull you will find it only a matter of learning that particular boat's characteristics. But the basics of sailing are the same, set course trim the sails and off you go.
BTW, there have been some grueling long distance catamaran races. The Worrel 1000 and Hog's Breath come to mind. Over 1000 miles of ocean racing. Not say you want to race in the ocean for days - only to say that your little Wave can take you places. You can learn to navigate and sail it all around the Gulf. I know that's not the goal, but just so you know, the boat is up to it.
TJC45 is offline
post #17 of 21 Old 07-12-2013
4KSB driver.
SHNOOL's Avatar
I'd add you might want to at least add a genoa to that wave (something just more than a lapper) to get a feel for the dynamics of adjusting trim for the slot, if you want the Wave to keep teaching (plus it'll add even more speed to it!).
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #18 of 21 Old 07-12-2013
overbored's Avatar
I would like to see a genoa on a Hobie Wave
post #19 of 21 Old 07-12-2013
4KSB driver.
SHNOOL's Avatar
All I could find is a jib...
SHNOOL is offline
post #20 of 21 Old 07-12-2013
overbored's Avatar
Not a genoa but but it would do for me. these are a blast
Sailing on a hobie cat NewsReader News Feeds 0 07-24-2012 05:20 AM
Catamaran for beach: Hobie Wave/Getaway or something else? themicah Boat Reviews 13 06-10-2011 06:06 PM
Hunter 17 or Hobie Wave jhgriff Boat Review and Purchase Forum 9 06-08-2009 01:24 PM
Square wave or sine wave inverter? wingNwing Gear & Maintenance 14 05-04-2008 10:06 AM
Hobie Cat sailors let it all hang out at Rehoboth races - Bethany Beach Wave NewsReader News Feeds 0 05-14-2007 09:15 AM
