Frustration unable to beat against steady wind & current Narr Bay - Page 2 - SailNet Community
 1Likes
post #11 of 18 Old 07-28-2013 Thread Starter
Re: Frustration unable to beat against steady wind & current Narr Bay
So many helpful suggestions here, thank you all. It probably was less than 3 kt current, but strong headwinds from our destination.
It is an S2 9.2A, and I guess sailing upwind is not her forte (I thought the Lewmar 30s were good). Clearly though, having a 155 genny on didn't help. My only other sail, a 135, tore and needs repair. Time to invest in a new 110? (swallow...) I hear new sails make a big difference in speed, or is that what the sailmakers tell you?
Clearly too we could have motorsailed. I have done that before and it went better.
I'm going to have to live with my mouse-powered 13hp Yan. Anything I could do to soup it up? Like one of those new 3 blade props that fold up? Does a 3 give you more speed or just power getting started?
Other than that, better planning. I could've avoided that combination of current and wind, just kept the downwind leg short, at least that day.
JIvories is offline
post #12 of 18 Old 07-28-2013
Captain Obvious
Sal Paradise's Avatar
What is it? A 2GM? There is nothing you can do about that mouse motor. One reason we let our old H31 go.
Sal Paradise
Senior Researcher - Dunning Kruger
Sal Paradise is offline
post #13 of 18 Old 07-28-2013
HANUMAN
RobGallagher's Avatar
What happened is common for this part of New England. There are a couple of other things that may play a part. Your Yanmar could also be a little over propped. This seems to be common with 1970's (ish) motors.
I'm gonna go out on a limb and say the current was not exactly 3 knots. In deep water it could have been running even faster.
Add to this, old sails?, rigging tuning?, stretched halyards?, a dirty bottom?, dirty prop?, etc. And no, I'm not flaming, I got an older boat too
So you have a boat that cruises at about 5 knots going into a 3+ knot current. You also have 15 knots of headwind, if you are making 2+ knots you now have 17+ knots of headwind. You are lucky to make 2 knots and that is really crawling. Hell, you are lucky to be making 1 knot with the head wind and wave action.
Welcome to New England. I can leave for Block Island three hours later than my friends, who seem chronically oblivious to Eldridges, and they can't seem to understand how I get there at the same time as them. Or often, as my boat is a faster by design than theirs, sometimes I even arrive before them. And the entire trip should only take 2.5-4 hours if one leaves with the proper current.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
post #14 of 18 Old 07-28-2013
+1 each to Mark and Xort.
I have been in similar conditions to the ones you are describing...beating into short, choppy waves, finding progress mind-numbingly slow. (no current to speak of, but a 55-mile sail dead into the wind gets frustrating quickly...)
I used to feel that motor-sailing was akin to failure, but as has already been said, if you have somewhere to go, it can be the right choice...no shame in that. you can shorten sail, turn on the motor, and have the benefits of easier motion (b/c of sails), plus upwind pointing (b/c of motor). The only loss is the peace and quiet.
give yourself a break. It sounds like you did everything you could.
A
aelkin is offline
post #15 of 18 Old 07-28-2013
outbound's Avatar
Sail the same place. First year in r.I.so like you just learnng but find large variations in strength of current at different areas. Some places short tacking near the shore keeps you in less current. Other places seems staying in deep water near the shipping channel works best. Slowly figuring it out. Less of an issue for me given higher hull speed but still annoying. Might be fun to check out with what trim and sails you point highest at different wind speeds. And do that at slack or in open water. Also check that your leech line isn't too tight. So far for us in anything over 10kts.do better with smaller headsail(solent). Think your S2 may also get most of it's drive from the main.
s/v Hippocampus
Outbound 46
outbound is offline
post #16 of 18 Old 07-29-2013
You're talking about water just south of Providence, ri?
My current ap says the max currents there are well under 1 knot in that area. Are there unplotted currents running much faster than predicted there or could it be the currents are much less than the 3 you estimated?
Other than Tiverton, I don't see anything very strong in all of the Naragansett.
xort is offline
post #17 of 18 Old 07-29-2013
outbound's Avatar
Your right.near Barrington or upper bay not really much going on. Thought op was having issues lower down.
s/v Hippocampus
Outbound 46
outbound is offline
post #18 of 18 Old 07-29-2013
chucklesR's Avatar
Beating at 45 degrees to current and wind while pinching along slowly just isn't efficient.
That's when the genny gets replaced with the iron genny and the mainsail becomes a stabilizer at 30 degrees.
chucklesR is offline
Unable to find a part. sailak Gear & Maintenance 6 10-03-2012 06:53 PM
Unable to Retrieve Messages captainpatty Announcements and Suggestions Box 2 08-16-2012 09:22 PM
Detailed Puget Sound wind / current forecasts? anthony11 Pacific Northwest & Alaska 6 08-12-2010 04:34 PM
djodenda, I am unable to reply farmboy General Discussion (sailing related) 6 07-13-2008 09:55 PM
Wind vs Tide/Current Hyperion Learning to Sail 7 07-07-2007 09:20 PM
