Topping lift - SailNet Community
 1Likes
  • 1 Post By Classic30
post #1 of 6 Old 08-02-2013 Thread Starter
davidpm's Avatar
Topping lift
Is their ever a time when it is correct form to use a topping lift to change the shape of the main sail.
IOW: Typically a topping lift is used to support the boom when lowering or raising the sail.
But if it is tight with the sail up it will slacken the leech.
Is this ever a good thing and if so when.
If it is sometimes used that features is lost when a ridged boom Vang is installed yes?
davidpm is offline
post #2 of 6 Old 08-02-2013
Asleep at the wheel
jimgo's Avatar
Re: Topping lift
Shorten the topping lift to add "depth" to the sail in light air.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
The Following User Says Thank You to jimgo For This Useful Post:
davidpm (08-04-2013)
post #3 of 6 Old 08-02-2013
Tartan 27' owner
CalebD's Avatar
Re: Topping lift
What Jim said.
Raise the topping lift in light air to increase draft, depth, curvature of the main.
Not for good air.
Everybody has one:
CalebD is online now
The Following User Says Thank You to CalebD For This Useful Post:
post #4 of 6 Old 08-03-2013
Re: Topping lift
As above, only if the weight of a heavy boom affects sail shape in near-calm conditions. Very rarely used in my exp.
Rigid vang could do the same if it is adjustable enough.
nolatom is offline
The Following User Says Thank You to nolatom For This Useful Post:
post #5 of 6 Old 08-04-2013 Thread Starter
davidpm's Avatar
Re: Topping lift
I guess you answered my real question. I knew it could be done I was just wondering if it was a common technique.
I did it a few days ago didn't remember doing it on purpose before.
Many time I've hoisted a sail and wondered why it was setting so poorly until I noticed the TL was too tight.
davidpm is offline
post #6 of 6 Old 08-04-2013
Once known as Hartley18
Classic30's Avatar
Dock
Re: Topping lift
Well spotted, David. Most people don't notice that the topping lift is too tight until after they haul on the mainsheet really hard.. and something (usually, but not always, the topping lift) breaks.
davidpm likes this.
Classic30 is offline
Topping Lift sehopkins Learning to Sail 16 05-04-2015 06:56 AM
Topping lift murphbmurph Gear & Maintenance 4 07-18-2012 06:14 PM
topping lift wumhenry Learning to Sail 24 08-04-2007 02:19 PM
Re-rig topping lift bestfriend Gear & Maintenance 26 07-30-2007 12:02 PM
Topping Lift jkrug Gear & Maintenance 18 05-04-2007 09:07 PM
