Rotten Luck - Stays & Dinghy Question - Page 2 - SailNet Community
 2Likes
post #11 of 13 Old 08-16-2013
Re: Rotten Luck - Stays & Dinghy Question
I agree that you are very lucky and should probably take it down a notch or two in your trust of your dad's sailing experience. No insults intended. His experience may be in the many other areas of sailing but when it comes to rigging, he is lacking. Listen to your boat, it is telling you something.
Ward H is offline
post #12 of 13 Old 08-16-2013
overbored's Avatar
not sure what you mean by the rigger repaired the broken shroud but when the rigging is at the point that it breaks it tells me that it is well beyond the end of it usable life and should be replaced. wire gets corroded where you can not see and it get worked hardened just from holding the mast up and being under tension and vibration. I would bet they are the originals and should have been replaced about 20 years ago.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #13 of 13 Old 08-17-2013 Thread Starter
Location: surrounded by three small children and 2 dachshunds + foster doxies
Rigger made two new lower shrouds with new hardware.
EDC
windwalker is offline
dinghy question jhgreen General Discussion (sailing related) 4 07-28-2012 08:34 AM
Sailing in Marin: Only luck is bad luck for Bay Area sailing team in Chinese regatta NewsReader News Feeds 0 11-11-2011 09:30 PM
dinghy question huguley3 Gear & Maintenance 12 06-16-2009 10:13 PM
another dinghy question Duck401k General Discussion (sailing related) 17 02-06-2009 01:17 PM
Not another Dinghy Question. Gulfislander Gear & Maintenance 13 05-21-2007 09:35 PM
