how much experience do I need - Page 2 - SailNet Community
 8Likes
post #11 of 45 Old 08-18-2013
Re: how much experience do I need
"I have no real sailing experience, but feel that I can do it. Am I fooling myself. ... about a mile offshore...How much sailing experience do I need to pull this off??
You'd kill yourself. Plain and simple, it is the ocean, it is not a lake. The waves are often larger, the shore is often lee, and there will be long stretches where you will be blown on shore, on rocks, with no way to avoid them. And that's oversimplifying it.
There are large sections off the Jersey shore, and then down by Hatteras, where the waters in-shore are considered treacherous and they've been killing people for centuries. Sailors stay out, way out, to avoid the conditions there.
Either you "drive the bus" down the ICW for weeks, or you go offshore and take careful note of when and where there are inlets you can use--or can't--to head in and take shelter.
You really want to read up on ocean sailing, on coastal sailing, and expand your horizons a bit. What you want to do is simply not feasible, much less safe.
Rapp likes this.
hellosailor is offline
post #12 of 45 Old 08-18-2013
The Coast Guard helo pilots and rescue swimmers aren't busy enough???
Seaduction is offline
post #13 of 45 Old 08-18-2013
For $15K there are many good boats available that could easily do it. For example, my own 28' S2 (1981) is valued at about $10K and would probably sell for $8K would do the job and there are many like her out there. I have been considering a Morgan 34 for $10K that would do the job nicely. Of course, I'd tear out all the BS you don't need (marine head, oven, fancy electronics, pressure water, etc) and go spartan and re-do the standing rigging, overhaul the engine (do it myself) and get by for very little while learnign all about the boat.
Frogwatch is offline
post #14 of 45 Old 08-18-2013
Here is a very good deal on a very good boat for $12500.
Pearson 35, Centerboard, Sailboat in Sailboats | eBay Motors
IF it is in half the shape they say.
post #15 of 45 Old 08-18-2013 Thread Starter
Thank you for the response. Im realy starting to like the sailing community. I get good vibes about the people. Im the type that gets an Idea, and goes.Ill deal with all the problems as they arise.However I think this type of adventure I better plan out a little more. I have been reading and will continue-Randy
Donna_F likes this.
randsail is offline
post #16 of 45 Old 08-18-2013 Thread Starter
I get the point, I will do a lot of research and practice on some big lakes before I go. Im not looking to kill myself. I want to have fun I plan on taking my sister and girlfriend whoever she may be. My Idea was to stay close to shore say a mile or two, Does that make sense?? If there are any problems I can get to land quickly--Rand
randsail is offline
post #17 of 45 Old 08-18-2013 Thread Starter
Thanks for the real truth, That's what Im looking for, I will continue to read up and learn as much as possible. Im about a year out and will take all the advice I can get. I have a habit of jumping into things, and pulling them off but with cosequences. I want this to be fun. Question:?? How far Out do I have to sail to avoid the problems but still be close enough to take cover. What are the worst seas I can stay out in?? Randy
randsail is offline
post #18 of 45 Old 08-18-2013
If you want to discharge overboard, you need to be 3 miles offshore.
post #19 of 45 Old 08-18-2013
The most female moderator
Donna_F's Avatar
Dock
...My Idea was to stay close to shore say a mile or two, Does that make sense?? If there are any problems I can get to land quickly--Rand
That makes perfect sense unless your thoughts are to anchor out there. With some experience you'll learn how to plan your voyages and how to determine which inlet is best under whatever circumstances you find yourself in. Some are safer than others. Guidebooks and local knowledge are your best sources.
If you want to stay offshore, are you prepared to stand a 24-hour watch? Because that is what is legally required.
Can you jump on a boat and go? Absolutely. Safely? Probably not. And passengers add an additional layer to your responsibility as the boat's owner.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is online now
post #20 of 45 Old 08-18-2013
Donna_F's Avatar
Dock
...Question:?? How far Out do I have to sail to avoid the problems but still be close enough to take cover. What are the worst seas I can stay out in?? Randy
Short answer is it depends on your skills and the strength of your boat. Not all boats are designed to take whatever the ocean throws at it.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
How much experience before... CambridgeKid Learning to Sail 35 09-05-2011 02:52 PM
My experience CapnRon47 Boat Review and Purchase Forum 52 05-21-2008 09:00 AM
Looking for experience in NC Bermuda30 Crew Wanted/Available 2 09-10-2007 12:13 PM
Looking for experience Michael201 Crew Wanted/Available 0 08-26-2006 10:30 AM
I need experience with you a1line Living Aboard 1 02-07-2002 05:10 PM
