Going ashore while on the hook - SailNet Community
 9Likes
post #1 of 22 Old 08-28-2013 Thread Starter
CaribDream's Avatar
As I contemplate a future life aboard for 6 months at a time, one thing that constantly enters my mind is leaving the boat on the hook. Anchor alarms and other methods are fine while aboard, but the thought of dragging while ashore always worries me.
Is it just time before one feels comfortable and stops incessantly worrying about this? How do you get over the anxiety of worrying about the boat while ashore?
Go sailing now my brother,
It's later than you think.
CaribDream is offline
post #2 of 22 Old 08-28-2013
Warm Weather Sailor
Vasco's Avatar
Re: Going ashore while on the hook
You don't. But good ground tackle helps.
Rick I
Toronto in summer, Bahamas in winter.
Vasco is offline
post #3 of 22 Old 08-28-2013
nodders's Avatar
There are anchor alarm apps that will send notifications of dragging to your IPhone. Personally, I don't know anything about them other than the fact that they exist!
CaribDream likes this.
I am not really from Toronto
nodders is offline
post #4 of 22 Old 08-28-2013 Thread Starter
CaribDream's Avatar
Makes sense, but in my mind the problem would be getting back in time. For instance, you went for a hike or something of the sort.
post #5 of 22 Old 08-28-2013
Yorksailor's Avatar
We have a 122lb Rochna on 7/16 4G chain usually at a scope of 7 to 10 to 1 and dive on the anchor. We also prefer the stern pointing out to sea so the boat does not go ashore.
We have dragged once in 1000 days at anchor and that was in 50 knots!
Yorksailor is offline
post #6 of 22 Old 08-28-2013
I doubt anyone is ever completely at ease leaving their boat for any great amount of time
Faster likes this.
sawingknots is offline
post #7 of 22 Old 08-28-2013
Call me Ishmael
blowinstink's Avatar
I heard Linn an Larry Pardey say that they will leave there boat on the hook for as long as 6 months with a 2 anchor setup with a swivel in the middle. Kinda hard to consider that "on-the-hook" though. There are definitely places and bottoms where I feel more comfortable than others.
Come not here if you have already spent the best of yourself
blowinstink is offline
post #8 of 22 Old 08-28-2013
Send a message via Skype™ to LaurenceU
Good question and I am interested in others responses. For me:
  • mooring to a single point with one anchor is least favourable. Though I can test and ensure it is holding well to resist the prevailing weather direction if the weather changes it may cause the anchor to break out and not re-set.
  • If anchored this way I will never be far from my yacht and will be very conscious of any changes in weather direction.
  • A fixed point mooring give much more peace of mind. But even picking up a mooring, I will dive on it to check the lines and give me confidence that I can go ashore for any extended time.
  • In the med we commonly lie to a bow anchor and tie the stern back to the shore with lines secured to rocks, trees etc. this Mediterranean moor gives much more peace of mind should there be a weather change.
  • I am aware of other anchoring schemes using multiple anchors such as Bahamian moor but not had to use these.
I am used to conditions where there will be a weather direction change. Generally this is predictable as a sea/land breeze system and I will make sure I am in attendance when the new wind comes in.
Laurence
LaurenceU is offline
post #9 of 22 Old 08-28-2013
I think there's truth in the above.
It comes down to making sure you're well set, and the local conditions. From your username it looks like you're heading for the Caribbean, I think it's a bit easier there where you're most often pulling off the beach in a lee harbour, it's shallow and clear enough to dive and check your set (as mentioned above). Sometimes the hike allows you at least occasional glimpses of your boat so you can keep an eye out.
In other areas where tides and winds can frequently shift it's a bit more of an issue, I think.
Overall probably the bigger problem, esp in popular anchorages, is the risk of someone coming in and anchoring too close, improperly, or worst, tripping your anchor and setting you free. So we're back to the above quote...
Faster is offline
post #10 of 22 Old 08-28-2013
I consider anchoring to be the most important skill one needs to learn for cruising (do sailing schools teach anchoring?). You should consider your anchors (multiple) as your primary pieces of safety equipment. You should try to inspect your anchor with mask and snorkel before going ashore. You should consider the direction both the wind and tidal currents set your boat and how it will set when the winds and tides change. This will often require two anchors. With only one anchor, I would feel uneasy leaving my boat out of sight for very long.
LaurenceU and CaribDream like this.
Frogwatch is offline
Tags
anchoring going ashore
Waterspout comes ashore in Tampa manatee General Discussion (sailing related) 0 07-09-2013 09:48 AM
No Tether Ashore? CaptainForce Cruising & Liveaboard Forum 5 08-02-2010 04:23 PM
Running engine ashore Sixbrothers Gear & Maintenance 15 05-15-2007 05:42 PM
Ready for time ashore ? BrianOdwyer Cruising & Liveaboard Forum 0 11-03-2004 01:51 PM
Hinckleys blown ashore VIEXILE General Discussion (sailing related) 5 06-15-2002 07:36 AM
