Attach Rope to Becket? - Page 2 - SailNet Community
 2Likes
post #11 of 17 Old 09-05-2013
Remember you're a womble
PaulinVictoria's Avatar
Re: Attach Rope to Becket?
Originally Posted by Jhiggy View Post
This seems like it would be the easiest. (Minus the knots) Any reference material on this?
The easiest option is rarely the best option on a boat.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #12 of 17 Old 09-05-2013
Markwesti's Avatar
I like to splice . I learned how to do it from the site the coastal passage . The one they call the Pro splice is the one I can understand . Hint, start out with new Sta- Set . Not Sta- Set X .
Markwesti is offline
post #13 of 17 Old 09-06-2013
I don't discuss my member
zz4gta's Avatar
What are you trying to connect? Do you have a picture or drawing?
Merit 25 # 764 "Audrey"
zz4gta is offline
post #14 of 17 Old 09-06-2013 Thread Starter
It will be the far end of my main sheet. It starts at the block with becket at the end of the boom.
Jhiggy is offline
post #15 of 17 Old 09-09-2013
zz4gta's Avatar
A splice is nice, but a knot will work just as well.
As long as the blocks aren't right on top of each other, there shouldn't be an issue either way.
zz4gta is offline
The Following User Says Thank You to zz4gta For This Useful Post:
Jhiggy (09-09-2013)
post #16 of 17 Old 09-10-2013
pdqaltair's Avatar
Originally Posted by PaulinVictoria View Post
Learn how to splice and do it properly, takes up less space than a knot and once you've done it a few times it's pretty straightforward, will only take you 10 minutes and you'll end up with a much better and nicer looking result.
No.
A splice is far longer than a knot, every time.
Splices can jam in blocks (fatter than rope, bad if it happens at the masthead).
You can cut off a knot and refresh wear spots. Can't do that with a splice (can't splice old line).
You can untie the knot, remove twist from the line, and re-tie the line.
There are good places for splices--even more so for 3-strand which doesn't knot as well--but most splices are for looks and not function.
Docklines--a knot often is the way of the chocks or something similar.
Chain--to rope--a knot won't pass the windlass.
Bridles--Often 3-strad (more stretch) and like dock lines.
Amsteel or similar--doesn't knot for beans.
Decorative stuff.
And I can't think of any others that truly matter.
As for sewing/seizing, any book on traditional marlinspike skill will cover it. Fully rigged (old) ships were full of seizings. Protection from sun and chafe can be a problem, but clearly the old timers thought is was sometimes--often--the best answer. Of course, doing it properly isn't really faster than splicing new line, but it often beats splicing old line.
Yes, I know how to splice, can do it quickly and even enjoy it. And I know when it's dumb.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
pdqaltair is offline
The Following User Says Thank You to pdqaltair For This Useful Post:
chipVA (10-07-2013)
post #17 of 17 Old 09-13-2013
A splice is longer but narrower than a knot, so for this particular application where the two blocks are never going to be close together (unless something is seriously wrong!), but you do want the line to run nicely between them as the lines are likely to be running quite close together, a splice is still the best solution IMHO, but whatever, the PO can do whatever he likes, his boat
Orange Crush
1974 C&C27 MkII
Reeving a fiddle block with becket and single block? dsimon General Discussion (sailing related) 4 06-26-2012 01:05 AM
Where to attach the sea anchor? MedSailor General Discussion (sailing related) 51 04-24-2012 06:38 PM
rope bridles vs rope travelers allergic1 Gear & Maintenance 1 05-25-2011 04:18 PM
Attach docklines to Pilings arknoah Learning to Sail 11 05-20-2011 10:56 PM
Changing from wire-rope to all rope hoppy Pearson 5 04-18-2011 04:42 PM
