-   Learning to Sail (http://www.sailnet.com/forums/learning-sail/)
-   -   Attach Rope to Becket? (http://www.sailnet.com/forums/learning-sail/103338-attach-rope-becket.html)
Jhiggy 09-04-2013 09:14 PM
How do you attach a rope to a becket?
davidpm 09-04-2013 09:33 PM
Re: Attach Rope to Becket?
splice in a loop
overbored 09-04-2013 09:40 PM
Tie a bowline. most of the line we have these days is way stronger then needed in the size that is easy on the hands so even if the knot makes it half the strength of a splice it will still be way stronger then you will need. splice the end if you have an excess of time to work on boat projects
davidpm 09-04-2013 10:32 PM
If you want to use a knot a halyard knot has the advantage of being shorter than a bowline. It will not untie very easy which in this situation is probably a good thing.
If you are creating a block and tackle system where you have two blocks one with a becket and one without and their is any chance the two blocks will get close to each other a short compact knot will allow them to get closer before something binds. It is called two blocking.
manatee 09-04-2013 10:53 PM
Sheet Bend (Becket Bend) | How to tie a Sheet Bend (Becket Bend) | Basics Knots
Double becket hitch
backed by :two half hitches on standing part (for easy/frequent untie)-- or --
seize bitter end to standing part (long term)
PaulinVictoria 09-04-2013 11:09 PM
Learn how to splice and do it properly, takes up less space than a knot and once you've done it a few times it's pretty straightforward, will only take you 10 minutes and you'll end up with a much better and nicer looking result.
kgs113 09-04-2013 11:43 PM
buntline hitch. Looks like a clove hitch on the standing end. Safe and solid. Buntline Hitch | How to tie a Buntline Hitch | Boating Knots
Lake Superior Sailor 09-05-2013 01:28 AM
Why not sew it . with whipped ends and cross stitching........Dale
Jhiggy 09-05-2013 12:38 PM
This seems like it would be the easiest. (Minus the knots) Any reference material on this?
Capt Len 09-05-2013 12:50 PM
I thick a splice would be most appropriate. A short splice in 3 stand would allow blocks to ''chocka block' but braided line splice would require some clearance in the sheave and should be well stitched and seized to prevent working out the spice with constant flexing as it runs through the sheave.
