Understanding the Polar Diagram - SailNet Community
 2Likes
post #1 of 13 Old 10-10-2013 Thread Starter
http://www.cc27association.com/pdf/iii_polar.pdf
Per the above link, if the wind is at 20 knots on a beam reach, my boat should theoretically be traveling at a speed of 7.25 knots? Is this diagram based on a 100 jib and main?
Thanks.
FirstCandC is offline
post #2 of 13 Old 10-10-2013
Zanshin's Avatar
Re: Understanding the Polar Diagram
Yes to the first part of your question. Since the configuration isn't specified in the diagram, I would assume what other manufacturers call "race conditions" which means that the polars are generated in the best possible configuration - often with the lightest fixed boat weight, lots of crew on the rails, and as much sail as the boat can carry. If the C&C can carry a 125% or more then that is what I would assume.
More important than the actual (and only hypothetically reachable speeds) are the curves themselves. So in this example, if you were to change your course by 30 degrees more off the wind you would speed up to almost 8 knots. With a bit of trigonemetry (or a race computer) you could figure out which wind angle will get you the fastest speed over ground- which is not necessarily going to approach that shown in the polars.
I've got official polars for my boat that I find useful despite not even coming close to their posted speeds on any point of sail (except for when heading closer to the wind than the angle in my polor, when my actual speed of 0 matches the theoretical speed of 0 )
Zanshin is offline
The Following User Says Thank You to Zanshin For This Useful Post:
FirstCandC (10-10-2013)
post #3 of 13 Old 10-10-2013
jzk
jzk's Avatar
There are two plots for each speed. One is downwind with a spinnaker, the other is upwind with the jib. You can see where they cross.
jzk is offline
post #4 of 13 Old 10-10-2013
grumpy old man
Probably safe to assume the plot includes a genoa. This is something you enter into the data before you plot.
I really don't use polar plots. I use the tabular form where there is far more data presented including VMG's upwind and down, heel angle and an indication of when to reef. You don't get any of this on the polar plot. It is very helpful to be able to see the difference in boat speed to VMG.
I tried to upload on of the tabular VPP's here but it doesn't want to take it.
I'll see what I can do.
OK, let's ee if you can read this sample from one of my boats.
It works! It's a bit small to read but I think you get the idea.
Bob's Blog ....
bobperry is offline
post #5 of 13 Old 10-10-2013
jzk
jzk's Avatar
You can see there are two plots. One is for a head sail, and the other a spinnaker.
jzk is offline
post #6 of 13 Old 11-10-2013
Is there a place I can obtain a polar diagram for several different boats? Or am I going to have to search for every boat specifically?
aaronsailor is offline
post #7 of 13 Old 11-10-2013
grumpy old man
Aaron:
You can go to U.S.Sailing and purchase polars for a wide variety of boats. Maybe you can find some nice yacht designer willing to spend some time digging through his files and providing you with some examples. I don't know any nice yacht designers, try Bruce Farr, so I'd go to U.S. Sailing.
jblumhorst and aaronsailor like this.
Bob's Blog ....
bobperry is offline
post #8 of 13 Old 11-10-2013
Trying to post that plot of Bob's a bit larger...
Faster is online now
post #9 of 13 Old 11-10-2013
grumpy old man
Thanks Faster.
I think Aaron will need much more info on each boat than just a polar. It would be helpful for him to have an overview of the entire design. Try an assemble a complete picture is what I have in mind.
Here is a sail plan for the polar you posted of my boat. This rig design is now obsolete but I think it was the one used for that polar. Maybe you can fix the sail plan so it's bigger please. Thanks.
Bob's Blog ....
bobperry is offline
post #10 of 13 Old 11-10-2013
.... Maybe you can fix the sail plan so it's bigger please. Thanks.
Done
C 27 TR Polar Chart Mark1948 Catalina 2 08-08-2012 11:17 PM
Velocity Predictions Polar Diagram CowbaySailor Seamanship & Navigation 11 07-17-2011 01:26 PM
Polar plots chucklesR General Discussion (sailing related) 7 02-01-2008 05:18 PM
How To Find Polar Diagram fo C&C 34? IrishMistRacing Racing 2 06-13-2007 01:02 AM
Polar datas for X 412 ArcaneX Racing 1 09-25-2005 05:40 PM
