Are Two sails better than One? - SailNet Community
post #1 of 7 Old 10-14-2013 Thread Starter
who
Does having a Jib in addition to the main sail make the boat go faster? Why would having 3 (with a spinnaker) would be even more advantages?
I read that the boat is limited by it's hull speed, if thats correct then whats the point of adding sails?
Thank you!
who is offline
post #2 of 7 Old 10-14-2013
Re: Are Two sails better than One?
1. Yes. the jib not only adds sail area, it bends and funnels the wind in a way that also makes the mainsail a more effective windfoil when going upwind.
2. Because when the wind is at just the right angle and speed, you can carry mainsail, jib, and spinnaker without any sail blanketing the other. Wrong angle, it won't work well.
3. Good question. Hull speed is not an absolute limit. But to speed above it, an inordinate amount of energy is required, and adding more sail area may just make her harder to handle without much increase in speed. Racers may take that chance and expend that effort, most other sailors won't. And, some of the lightweight, flat-bottomed skiff-type sailboats (large and small) don't have a "hull speed", because they can rise up and plane, or at least surf.
Or even rise up and "foil". You watched the America's Cup??
nolatom is offline
post #3 of 7 Old 10-14-2013
Even if the wind was strong enough that you could get to hull speed with one sail, that wouldn't be very balanced. The boat would pull one way or the other. Far better to have two smaller sails in strong winds than one big one.
But most of the time when the winds are light, you are going less than hull speed and are trying to put out as much canvas as possible.
MarkSF is offline
post #4 of 7 Old 10-14-2013
The most female moderator
Donna_F's Avatar
Dock
Thank you!
Spinnakers are typically used only in downwind light air sailing.
Yes, the boat is limited to it's hull speed in most cases and having both the main and the jib will help you reach that speed. Most of the time. They work as a team, each having a different function, and someone else can go into the physics of it better than I can.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is online now
post #5 of 7 Old 10-14-2013 Thread Starter
who
Wow thanks for the responses everyone this is helping me understand much better. I appreciate everyones response!
who is offline
post #6 of 7 Old 10-14-2013
overbored's Avatar
the number and size of your sails are changed to keep the boat at a desired speed. some time there is not enough wind to go hull speed and just beacuse there is enough wind you may not want to go that fast. having a main and a jib will make the boat sail a lot faster upwind when it is hard to reach hull speed. most boats will not sail upwind any where near hull speed.
"GOLD RUSH" PRINDLE 16
overbored is offline
post #7 of 7 Old 10-14-2013
Not Finished Yet
RainDog's Avatar
What overbored said, but you can also always fly a spinnaker in 30 knots and go way over hull speed if you have the right boat.
RainDog is offline
Completed my cruising sails inventory with 11 sails jameswilson29 General Discussion (sailing related) 20 04-14-2013 10:17 AM
new sails blakeyoung General Discussion (sailing related) 23 03-08-2013 10:06 AM
Racing Sails Vs. Cruising Sails??? NewportNewbie General Discussion (sailing related) 2 10-27-2011 03:25 PM
North Sails vs North Sails Direct DrB Gear & Maintenance 0 06-25-2009 10:00 PM
Teralani Sailing Adventures - Snorkel Sails, Sunset Sails and Whale Watched from Kaanapali Beach, Maui (About.com) NewsReader News Feeds 0 10-06-2006 12:15 PM
