Learning to dock shorthanded - Page 5 - SailNet Community
Advertise Here
Go Back   SailNet Community > Skills and Seamanship > Learning to Sail
Like Tree20Likes
Old 11-06-2013
abrahamx is on a distinguished road
Re: Learning to dock shorthanded
Maybe I just have an easy slip. I just got my first bigger boat this year and was nervous about docking. I have to say that I find there is nothing to it. I tried it once with the wife onboard but told her to let me do everything. Was a piece of cake. I have since gone out singlehand several times and never have an issue docking. I am the clinton river and the slips are right on the river. I just drive up the river and make a left turn into the slip. I bring the boat to a stop, kill the engine and grab the boat hook. Snag my two back lines, then hop off and grap my bow lines off the wall and tie up. Just for the hell of it I tried backing in and had no issue at all. Just backed right in. Although I could not tie off that way because the slip is not rigged for it and I think I was bottoming out because I could not get less than about two or three feet from the seawall. And its a tartan 30 which I have always heard was a pain to back up. I found no issue at all. Not sure what gives but I never even think/worry about docking. Was/is way easier than I was thinking.
Reply With Quote Quick reply to this message Share with Facebook
  #42
Old 11-06-2013
jimgo's Avatar
Asleep at the wheel
jimgo is on a distinguished road
Abraham, next time, try backing in from the other direction. Then I suspect you'll understand why people say she doesn't back well.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
  #43
Old 11-06-2013
Ninefingers is on a distinguished road
Originally Posted by bshock View Post
So I came up with our own method that has (so far) worked perfectly every time. So if you're interested in backing in, let me know. It's a bit complicated and hard to explain. I wish I could get someone to take a YouTube video of it, but it's always just me and my wife on the boat.
Yes please!
  #44
Old 11-06-2013
bshock is on a distinguished road
This is my procedure for docking stern first. Rather than re-type from a post I did on another website, I just provided a link. I hope that's not bad ettiquete. I don't necessarily wish to steer people away from Sailnet.
Association Forum - VK docking system in pictures
The Following User Says Thank You to bshock For This Useful Post:
jimgo (11-06-2013)
  #45
Old 11-06-2013
PAULCR1's Avatar
Grumpy Cat
PAULCR1 is on a distinguished road
We, my wife and I, are both in our mid 60's and had to struggle with docking. She just didn't have the arm strength, and I didn't have the skill, to stop our boat, 36', dead in the water at a dock. We switched roles and with the aid of a "Docking Stick" and our center cleat we now have no problems docking. We have found out that she has a much 'softer' touch at the helm than I. Hope this helps.
davidpm likes this.
Theodore Roosevelt said “In any situation, the best thing you can do is the right thing; the next best thing you can do is the wrong thing; the worst thing you can do is nothing.”
  #46
Old 11-06-2013
davidpm's Avatar
davidpm is on a distinguished road
Looks like a nice simple system.
  #47
Old 11-06-2013
outbound is on a distinguished road
Something that was drilled into me was
1.rudder only steers when water moving across it.
2.only get prop walk when prop is spinning
3. when bow goes to right stern goes to the left( and vise a versus) e.g. boats especially fin keel boats pivot
therefore when docking and want boat to steer not walk use very brief but strong bursts of engine with neutral in between
Use the pivot to your advantage.
use the wind to aid docking. if wind pushing you into slip and docking bow first ghost using bursts of reverse to position boat
go as slow as you can.
don't stand behind the wheel constantly or be stuck on side where throttle is -move around to see where you really are.
my 2 cents
s/v Hippocampus
Outbound 46
  #48
Old 11-06-2013
eherlihy's Avatar
Learning the HARD way...
eherlihy will become famous soon enough
I never leave the dock alone. The problem is that I just can't predict what conditions will be when I return. The wind can be on the nose, to port, to starboard, or behind me. Currents run parallel with my slip. The exit to the marina is to the left in the pic below.
Here is my situation;
I'm in the slip occupied by the boat in yellow. You can see that the fairway is tight, and there is usually a SeaRay 340 in the slip next to me...
My boat is 35' long, and I believe that the distance from the piling to the end of the slip is about 33'.
Here is another view;
What I do when leaving is; Double the green line on the bow. Start the motor, cast off all lines except the green bow line, put the boat into reverse. Because prop walk will push my bow to starboard, I do not let the crew on the bow release the green line until the bow swings to port (or is next to the finger pier). I even encourage them to give a tug on the line to help pivot the bow to starboard.
If the crew on the bow releases the line early, and the bow does not swing to port, I will back down the fairwary.
When returning;
I have fenders out, and bow, stern and spring lines rigged before I enter the fairway. When I enter the fairway, I have crew go up to the shrouds (the red arrow), with the spring line (red) in hand, and prepare to step onto the dock. As soon as they can, I have them step onto the dock, and secure the spring line first. I then put the boat into reverse to stop any forward momentum, and prop walk pushes the stern to snuggle against the dock. I then tell them to QUICKLY go forward, and grab the port bow line (green) to keep me from swinging into my neighbor's SeaRay. As they do this, I step off and secure the stern line.
I am open to suggestions, but I can't imagine doing this single handed.
USCG Licensed OUPV Captain, ASA 101/103/104/105/106/118 Certified Instructor - Also certified in Recreational Marine Electrical Systems
  #49
Old 11-06-2013
Delta-T's Avatar
Delta-T is on a distinguished road
I would want to be in the Searay's slip. That would help with your approach and launch. And if you need to dock on the Port side then get a slip on the opposite side of the main dock. Put a request into the yard to be relocated, I had to wait four years till I got what I wanted. And I have the same issue you have, my boat is longer then the dock finger making stopping the boat with the dock cleats difficult, needing to tie a dock line off up near the companionway.
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
  #50
Old 11-06-2013
tomandchris is on a distinguished road
When returning;
My dock set up is almost identical to yours. True, you will never be able to predict what the wind will be doing later, but it should be able to be handled. My boat is a C34, so 35' LOA, and I single hand 90% of the time and dock without help almost 100% of the time.
I have one long spring line that is measured and marked for my slip. It runs from the mid ship cleat, or a shroud on other boats I sail, outside the lifelines to the back cleat. That line is dropped over the cleat or post on the end of my pier and I control it as the boat moves forward until it stops 6" from the bow touching the dock. Nobody jumps off and does anything quickly, it is controlled and so far never an accident.
The worst winds for me are a N or NE wind on my stern as it forces me to come in a little hot. However, I have done it in above 30Kts of wind with little problem. A E wind wants to push me off the pier, but the spring controls that and snugs me in.
I use the same spring line when traveling, it is just not pre measured. Once that line is on I am comforable with a port of starboard tie.
Tags
docking , motoring
You may post attachments
You may edit your posts
2011 Ocean Planet Trophy for Shorthanded Racing in Maine catamount Racing 0 03-28-2011 09:09 PM
Thoughts and Q on Mainsail Systems for Shorthanded Boats kreton General Discussion (sailing related) 11 10-12-2006 03:19 PM
Shorthanded Sail Handling Jon Shattuck Gear and Maintenance Articles 0 10-30-2000 07:00 PM
Shorthanded Sail Handling Jon Shattuck Her Sailnet Articles 0 10-30-2000 07:00 PM
Learning to Use SSB Sue & Larry Gear and Maintenance Articles 0 08-11-2000 08:00 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
