Mast step...? - SailNet Community
 1Likes
  • 1 Post By benesailor
post #1 of 5 Old 12-14-2013 Thread Starter
Mast step...?
As a few of you may have noticed i am brand new to sailign and have a "boat load" of questions lol. once is about my mast. A new friend of mine sent me a picture of his mast step on his FJ and min looks pretty different, almost scary. There is just a shallow channel, that the mast rests in, and a flat plate on the bottom of the mast. i dont see how it is supposed to stay put if there isnt anything to really stop it from sliding forward of aft other than the sidestays and forstay, is that enough? i expected some kind of a notch or a pin to locate it. but if you guys tell me its normal i will be good with it. here are the pictures of what i am talking about
fj007 is offline
post #2 of 5 Old 12-14-2013
Re: Mast step...?
You're looking at the mast upside down!
jimgo likes this.
benesailor is offline
post #3 of 5 Old 12-14-2013
Re: Mast step...?
Just kidding...looks normal to me....Then again i don't really know much about FJ's
post #4 of 5 Old 12-14-2013 Thread Starter
Re: Mast step...?
lol thanks
fj007 is offline
post #5 of 5 Old 12-14-2013
Dog Ship's Avatar
Re: Mast step...?
Your mast should sit in that grove in the bottom of the hull.
You want to be able move the mast fore and aft so you can trim or balance the boat for sailing but you do not want any lateral movement.
You could simply attach a piece to the bottom of your mast that will fit in that grove to eliminate any sideways movement but will still allow for adjustment fore and aft.
The compression from the rig should be enough to hold it from moving for and aft but if not, once you have found the "sweet spot" cut some blocks that will fit in the grove to hold the mast from moving around.
We have three rules;
No screaming.
No bleeding on the sails.
No slobbering on the charts.
Dog Ship is offline
Mast leaning forward (new mast step) Amateur_Expert Gear & Maintenance 22 06-26-2013 09:22 AM
My new mast step sailordave Gear & Maintenance 4 03-18-2013 11:50 AM
mast step hindsight SailNet FAQ 0 05-28-2012 01:34 AM
Is there a step by step for a stepping of the mast? Skipper Joe Gear & Maintenance 5 07-15-2009 07:45 PM
Need new mast step dflyin1 Gear & Maintenance 2 03-24-2008 05:44 AM
