Using Jib and Genoa at the same time to create spinnaker - SailNet Community
 1Likes
post #1 of 15 Old 12-20-2013 Thread Starter
I haven't tried this but it keeps sticking in my head. Could you raise both the hank on jib and genoa on the same forestay? You could pole one out or both if need be. Do you think this would work?
Zac Penn is offline
post #2 of 15 Old 12-20-2013
Re: Using Jib and Genoa at the same time to create spinnaker
Yes, it could be done... but.... are the hoists identical? If you used one halyard then neither sail is likely to get proper luff tension.. do the hanks 'align' in a good way? Using two halyards, if the hanks don't interfere you might get some decent set, but both need releasing to drop either..
And it would be a handful on the foredeck when it does all come down. All in all it's probably easier to use main and headsail..
Faster is online now
post #3 of 15 Old 12-20-2013
Just fly the lighter sail loose luffed
barefootnavigator is offline
post #4 of 15 Old 12-20-2013
Minnesail's Avatar
This site on self-steering talks about using two hank-on jibs for self-steer dead downwind:
Blue Anarchy Sea Collective >> Self Steering Without A Windvane
Catalina 22
on a starboard tack
Minnesail is online now
post #5 of 15 Old 12-20-2013
paulk's Avatar
Boats set up for flying twin jibs often have double forestays so each jib is hoisted on its own forestay. That way the hanks don't interfere with each other. A double-slotted roller-furler setup could work the same way. You obviously need two halyards to do this, and any roller-furler snafus would be twice as bad as they might have been otherwise. Most often people seem to fly two jibs of the same size - as in the photo above . This helps to keep the forces even and make it easier to steer a straight course.
paulk is online now
post #6 of 15 Old 12-20-2013
tdw
Super Fuzzy Moderator
tdw's Avatar
Though I've never tried it myself, I've heard it said that the twin headsail arrangement induces the most awful rolling.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is online now
post #7 of 15 Old 12-20-2013
I've seen a light air 'drifter' that was a 2 ply sail on a common luff... tie the clews together to use it as a light air 'genny', split them on separate sheets and open it up butterfly style for running.. might make more sense than fighting two separate sails on hanks. - plus equal areas as you suggest.
post #8 of 15 Old 12-20-2013 Thread Starter
Wow that sounds really cool. This kind of sail would keep you in the non-spinnaker class wouldn't it?
I am going out on the boat tomorrow so maybe i will play with this idea and see what happens. I am thinking about attaching the single halyard to both sail heads, attach the tack of the genoa to the deck and run a line from the tack of the jib to the deck this way the halyard can apply tension on both sails.
Zac Penn is offline
post #9 of 15 Old 12-21-2013
I have raced downwind on a boat flying the mainsail and twin gennys on a furler with two slots, in 18-25 kt winds. The boat was extremely stable, with no rolling at all. The second genny increased our boat speed about 3/4 kt. or more. With all three sails flying, the steering angle is narrow. You have to find the angle where the wind can get to all three sails without having one of the gennys blanketed by the mainsail. We tried it with one genny poled out and with both of them flying free, and they worked well both ways.
Sailormon6 is online now
post #10 of 15 Old 12-22-2013
capt vimes's Avatar
This sail configuration is called in german passat sail...
It was developed at a time where wind vanes and autopilots where not very common... So you linked the two sheets back to your tiller or wheel and thus creating an effective self steering system...
But you needed to deploy 2 poles which the majority of the boats don't have, let alone all the lines for that...
Google passatsegel and look for images...
Oh and btw:
In this configuration you do not fly a main and thus the boat tends to roll...
With the main up, the center of effort of the sails is to leeward and hence stabilizing the boat... Without the main, the center of effort is at the centerline and then rolling is only to be expected...
capt vimes is offline
The Following User Says Thank You to capt vimes For This Useful Post:
Zac Penn (12-22-2013)
Jib vs Genoa vs Spinnaker eagles_dare13 Learning to Sail 13 09-30-2015 06:25 PM
Genoa/Jib Tracks andrewoliv Gear & Maintenance 15 09-28-2011 09:53 AM
Jib/genoa lines mpc7002 Gear & Maintenance 13 07-30-2010 11:13 AM
Jib vs Genoa calamitas Learning to Sail 7 08-10-2007 11:29 PM
When to use genoa or jib bcooper67 Learning to Sail 1 09-16-2002 02:07 PM
