Physics of Sailing - Page 2 - SailNet Community
 10Likes
post #11 of 31 Old 01-02-2014
s/v Ilya
arknoah's Avatar
Re: Physics of Sailing
Originally Posted by svHyLyte View Post
Hence the old Saw: "When in Doubt, Let it Out."
And I, like many other sailors, have never forgotten that. It must be valuable, huh?
Ilya's Adventures:
____________________________
And straight on 'til morning
arknoah is offline
post #12 of 31 Old 02-15-2015
arrgh!
titustiger27's Avatar
Dock
Originally Posted by billyruffn View Post
Found this on a surfing expedition today. Thought it might be of interest to some in present company.
Happy New Year
Enjoyed the video --- was surprised about this thread.... I used to read a lot of cycling forums and if there was a 'physics of cycling' thread started it would go on for ever... with knock down drag out arguments with engineeers... so I was kind of surprised at this one..
I have a question, related to physics of sailing
When the wind blows people go to the high side to try to bring the sail more vertical...in smaller boats they even hang out on a trapeze
I am wondering is that better than a) easing out the sails; b) reefing; c) heading more to the wind...
and why
Vector X Y
titustiger27 is online now
post #13 of 31 Old 02-15-2015
TakeFive's Avatar
Originally Posted by titustiger27 View Post
...When the wind blows people go to the high side to try to bring the sail more vertical...in smaller boats they even hang out on a trapeze
There are so many dimensions to this answer that others who know more than I can go on for hours.
But one thing that I will point out is that the answer may be totally different depending on whether it is a planing hull (small boat), a displacement monohull (larger boat) or a multi-hull.
As usual, the only universal answer is "it depends."
Rick S., Swarthmore, PA
TakeFive is offline
post #14 of 31 Old 02-15-2015
arrgh!
Dock
Planing... I thought that only worked when the wind was behind you?
A new thought --- what if you put more weight in the keel to keep it upright
Vector X Y
post #15 of 31 Old 02-16-2015
jerryrlitton's Avatar
Originally Posted by Torch View Post
An airplane wing stalls when it looses its lift. So, from that perspective a sail luffing is a good analogy. But your right that an airplane wing looses it's lift due to insufficient wind speed over it's leading edge which is not what a sail does. Most sails, unlike airplane wings, are not rigid so it's a challenge to compare the two in all circumstances.
Actually sort of backwards. An airplane wing or rotor blade will lose lift when it stalls. However I can make an airplane wing lose lift or a rotor blade lose lift just by unloading (think reducing angle of attack) without stalling. Also stalling is not a direct function of indicated (actually it is calibrated) airspeed. The stall angle can be exceeded at any airspeed (within the aircraft structural limits of course).' Google acccelerated/high speed stall. I am sure the pictures they can draw you will far exceed my poor grasp at math. It is all about the exceeding the critical angle of attack gentlemen, not about speed. Remember you can change the critical angle of attack somewhat by changing wing shape such as adding leading, trailing edge devices such as slats and flaps. The sail is a wing.
Part time PADI instructor, part time sailor. Full time having a blast.
S/V TEMPTATION
Islander 44
jerryrlitton is offline
post #16 of 31 Old 02-16-2015
weinie's Avatar
The analogy of wind blowing over the top of the paper (a curved surface) to cause lift is incorrect.
See why here:
experiments @ sailtheory.com
weinie is offline
post #17 of 31 Old 02-16-2015
See why here:
That is sort of true since most lift is formed when an angle of attack is present. However lift is relative and is formed when there are two sides of unequal pressure. As you know some aircraft have laminar flow (think symmetric) and with zero AOA (angle of attack) no lift is present. Look at the keel of your boat. Symmetric, no unequal lift until you introduce it. Like when you raise your sails and now your keel tries to resist leeway.
http://www.scienceclarified.com/ever...Principle.html
S/V TEMPTATION
Islander 44
post #18 of 31 Old 02-16-2015
and why
The main reason why people move to the high side is to keep the boat flat, so that the shape of the hull that is in contact with the water is symmetrical. As the boat heels, the underwater shape becomes asymmetrical, and that creates drag. Coincidentally, keeping the boat upright also affects the direction from which the wind strikes the sails, but that isn't a principal concern.
Efficient sailing is not about maximizing sail power all the time. Efficient sailing is about using the available power efficiently, while minimizing drag. In light air, the boat is capable of efficiently using every bit of power that the sails can generate. In strong winds, the sails are capable of generating more power than the boat can use efficiently. In the latter case, the objective is to bleed off some of that excess power. Easing out the sails, reefing and heading more into the wind are techniques that you can use to reduce excess power.
nolatom likes this.
Sailormon6 is offline
post #19 of 31 Old 02-16-2015
TakeFive's Avatar
Originally Posted by Sailormon6 View Post
...Efficient sailing is not about maximizing sail power all the time. Efficient sailing is about using the available power efficiently, while minimizing drag. In light air, the boat is capable of efficiently using every bit of power that the sails can generate. In strong winds, the sails are capable of generating more power than the boat can use efficiently. In the latter case, the objective is to bleed off some of that excess power. Easing out the sails, reefing and heading more into the wind are techniques that you can use to reduce excess power.
This is traditional theory for displacement hulls, where any power in excess of what's needed to achieve "hull speed" results in loss of comfort and safety that most cruisers find unacceptable (but which racers may tolerate in the interest of getting a few hundredths of a knot extra).
However, your explanation does not necessarily apply for planing hulls, for which all power, if handled properly, could translate to more speed.
I believe the person who raised this question may have a planing boat.
As I said before, the correct answer depends on the boat, and the "correct" answer for displacement hulls may not apply to planing hulls.
TakeFive is offline
post #20 of 31 Old 02-16-2015
Easing out the sheet and or heading more into the wind reduces angle of attack thus reducing lift (thrust)
S/V TEMPTATION
Islander 44
The physics of a mooring ball... MedSailor General Discussion (sailing related) 11 04-01-2013 10:59 AM
IB Extended Essay on physics in sailing... help!!! yashgore SailNet FAQ 6 08-06-2011 09:31 AM
The Physics of Railmeat smackdaddy Racing 50 01-08-2011 09:33 PM
Physics of the random overhand sneuman General Discussion (sailing related) 6 03-12-2005 02:20 PM
