Closer to the wind question - Page 3 - SailNet Community
 11Likes
post #21 of 32 Old 02-03-2014 Thread Starter
rbyham's Avatar
Re: Closer to the wind question
Thanks again for the good coaching here. I did get out yesterday here. Lovely day with light winds. Interestingly I hit the harbor just as the first class of racers were starting. All total had about 30 boats jostling for position as 4 classes were called. I hung on the edge to go along with what looked my group. Wanted to see if I could hang. First leg was guess where? Upwind :-) so I tried as told sheeting in the full 135 nice and tight. Tighter than I have ever had her. It was aperfect conditions for testing as winds were 6-8 and no fear of being overwhelmed. I felt the difference immediately. Good speed and power and I basically kept up off to far side of course about 100yds from nearest racer. What a blast. Whereas previously the Genoa was noisy and easily luffed as I tried to gain to winward this time she was very settled and just pulled. GPS had us between 3.4 and 4.4 on that leg. But like I said I was in the hunt. So all this to say I think I get it on the headsail setting to win ward but will keep practicing. I am sure it will be a whole different day in 10-15. :-)
bobperry likes this.
rbyham is offline
post #22 of 32 Old 02-03-2014
jackdale's Avatar
Sounds like a great sail.
There is about a compromise between pointing speed. In light airs you want a fuller sail shape (ease the sheet a little). As the winds pick up you will notice the headsail pull away from the spreader - harden the sheet.
A quiet genoa is a fast genoa. Next try playing the leech line. Ease it out until the leech just flutters, then slowly harden it until the sail just stops fluttering.
After you get headsail trimmed, trim the main. That is another lesson.
jackdale is offline
post #23 of 32 Old 02-04-2014
SchockT's Avatar
That's great! It sounds like you are on the right track. Getting the sails as flat as possible will be increasingly important as the breeze picks up. Don't be afraid to grind on halyard as it gets windier. If you don't already have them, putting telltales on the lower, middle and upper sections of your headsail a foot or so back from the luff. They will tell you alot about what is going on with your trim and with your helming as well.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #24 of 32 Old 02-04-2014
grumpy old man
6:
Nope. Sorry. I have done far too much racing to think 6" of the spreader is hard on the wind. I wopuld only do that if I was looking for some power to punch through waves and not pointing angle.
Ham:
Racing is really the only way to learn how to get the most out of your boat. Congtrats on the experiment.
Bob's Blog ....
bobperry is offline
post #25 of 32 Old 02-04-2014
Originally Posted by CruisingCouple View Post
With the Iron Spinnaker zero degrees off the wind is no problem. That's usually the best option in a narrow channel.
Wondering why sailboat skippers need to call for a tow when the engine is not working
To rbyham:
Keep sailing, ask and learn
knuterikt is offline
post #26 of 32 Old 02-04-2014
It sounds like you were in the groove.
Generally, the difference in sail trim, between 6-8 and 10-15, is that, at the higher wind speeds, you'll want to trim the jib even a bit flatter. That means a bit more tension on the jib sheet. It also means that, when you raise the jib, you should slightly increase the halyard tension. In strong winds, you will need a winch handle to help you trim the sails as tight as they need to be.
Also, whenever you flatten the jib, you should think as well about flattening the mainsail, because it is also probably becoming overpowered. The mainsail can be flattened by increasing the tension on the halyard or cunningham, and by increasing the tension on the outhaul. There are also other devices that can be used to shape the sails, but you can learn how to use them after you have learned the basics.
It helps to keep the big picture in mind. In all but light winds, the genoa and mainsail are capable of producing more power than the boat can use efficiently. Your objective is to maximize their power in lighter winds, and to progressively reduce their power in stronger winds. You increase their power by making their shape more full, and you reduce their power by making them flatter and by reducing their size.
Finally, keep in mind that the sails don't operate independently of each other. You always want to balance the amount of power generated by the jib against the amount of power generated by the main sail. If you depower one, you should generally depower the other. If you don't, and have too much power being generated by one or the other, then the boat will tend to pull one way or the other, and you will have to use more tiller pressure to hold your course. Whenever you feel tiller pressure, the rudder is acting like a brake, slowing the boat. By balancing the pressures between the main sail and jib, you can reduce that tiller pressure to a minimum.
nolatom likes this.
Sailormon6 is offline
The Following User Says Thank You to Sailormon6 For This Useful Post:
Steve in Idaho (02-05-2014)
post #27 of 32 Old 02-07-2014 Thread Starter
rbyham's Avatar
Thanks all... Lots of good help here. I think one of the biggest learning points at this stage is getting over fear of cranking down on rig. Tightening down on halyards and jib sheets hits a point where everything feels real hard leaving me nervous both in terms of popping rigging and being overwhelmed. I have no idea where are breaking points to for standing or running rigging so I tend to just take a conservative approach. I guess a question like that reveals how much a rookie I am... :-)
rbyham is offline
post #28 of 32 Old 02-07-2014
One day when you're at the boat with someone, put them in a bosun's chair and try to winch them a few feet up the rig.. just as deadweight.. A 180 pounder is HARD to crank up without their helping themselves.. the rig and the rigging can easily handle that load and then some.
It will put a bit more perspective on how much 'load' you're putting on things when you're sailing.
Sounds like you're making headway.. keep at it!!
Faster is offline
post #29 of 32 Old 02-07-2014
Trust the person who designed the boat. He knew the loads that the rig would have to withstand, and specified the cable and hardware that was adequate to do the job. Likewise, trust the person who designed and constructed the sails. He reinforced them with enough layers of sailcloth at the crucial points so that you could tension the sails as much as necessary without hurting them. It always amazes me to see the tremendous loads we put on sails and rig, without damaging them. Usually the only weak point is the boat owner. If he maintains the sails and rig, repairing and replacing them as necessary, the likelihood of a major equipment failure is very small.
post #30 of 32 Old 02-09-2014
L124C's Avatar
I doubt you are ever going to sail closer than "30 degrees" off the wind. Some boats only do 45.
It's a good idea to take the time to sail under main only then jib on all points of sail to see how your boat performs under each. For example, some boats won't tack with jib only. Good to know if you get in a bind sometime. Oh, and turn the GPS off until you learn to sail. Pay attention to the conditions and the boat using your senses, not the gadgets!
L124C is offline
Wind Direction Question from Noob... mike21070 General Discussion (sailing related) 40 09-18-2013 09:23 AM
Wind generator and refridge question ereiss Gear & Maintenance 1 07-20-2010 07:08 AM
Main lies closer to wind than jib jaschrumpf Gear & Maintenance 5 07-07-2010 08:15 AM
Wind Transducer location question? gtod25 Gear & Maintenance 2 11-04-2008 09:58 AM
NOAA Wind Graph Question Bryan53 General Discussion (sailing related) 7 04-11-2007 03:22 PM
