Closer to the wind question - Page 4 - SailNet Community
 11Likes
post #31 of 32 Old 02-09-2014
Owl
-OvO-'s Avatar
Re: Closer to the wind question
The key to all kinds of mechanical devices is knowing which ones are big and strong and which are light and fragile -- and then using the appropriate-sized tools and appropriate forces on each. And knowing when brute force is just making things worse, so try applying other tactics.
I say this having broken off the heads of quite a few bolts and being forced to drill out and tap new threads to repair
-OvO- is offline
post #32 of 32 Old 02-12-2014
Water Lover
Location: New Mexico, USA (Heron, Elephant Butte lakes); Arizona (Lake Pleasant)
It's harder when you're singlehanding or have green crew, but getting the timing down right on your tacks and bringing the sheets over quickly and smoothly after you've got the boat starting to tack can really help reduce the workload of grinding in the new windward sheet, as well as help the boat come up to speed faster on the new tack and lose less speed in the tack. If you're singlehanding a tiller boat, you might be able to use shock cord to make a tiller tamer that will let you let go of the tiller for a few seconds to take care of the sheets and winches.
rgscpat is offline
Wind Direction Question from Noob... mike21070 General Discussion (sailing related) 40 09-18-2013 09:23 AM
Wind generator and refridge question ereiss Gear & Maintenance 1 07-20-2010 07:08 AM
Main lies closer to wind than jib jaschrumpf Gear & Maintenance 5 07-07-2010 08:15 AM
Wind Transducer location question? gtod25 Gear & Maintenance 2 11-04-2008 09:58 AM
NOAA Wind Graph Question Bryan53 General Discussion (sailing related) 7 04-11-2007 03:22 PM
