stopping on a dime - Page 2 - SailNet Community
 3Likes
post #11 of 22 Old 02-13-2014
ASA and PSIA Instructor
Re: stopping on a dime
Originally Posted by dixiedawg View Post
In our sailing class last year, the instructor briefly touched on the subject of bringing the boat to a stop in the shortest possible time. But neither my wife nor I can remember what he said the maneuver was!
Would it simply be heaving to?
Heaving to is a process for stopping the boat...but not the quickest. The quickest maneuver is rapid port-starboard full movement of the rudder, naturally combined with luffing the sails. On a boat like a Colgate 26, which has a rudder which can be turned 360 degrees, a couple of repeated 90 degree swings stops the boat almost immediately.
sailingfool is offline
post #12 of 22 Old 02-13-2014
Thanks Jackdale, Much better diagram, I'm also more familiar with being hove to while picking up as opposed to luffing up as shown on the US Sailing site. I've recovered more hats, gloves, camera bags and fenders than people, keep hoping for the bag of money that fell off a southbound panga.
"Just call me TB"
capttb is offline
post #13 of 22 Old 02-13-2014
The hardest thing I've had with getting a boat to stop on a dime was getting the dime to float!!!!
Past that, lots of good advice on this thread!
fred1diver likes this.
TJC45 is offline
post #14 of 22 Old 02-13-2014
Once known as Hartley18
Classic30's Avatar
Dock
Ha! None of that would work on my boat.. it'd just ignore your rudder and sail movements and keep going.
Heave-to seems to be something that works on ALL boats (not just pocket racers) from Tall Ships downwards perhaps why it is taught to be the quickest.
Classic30 is offline
post #15 of 22 Old 02-13-2014
no longer reading SailNet
Alex W's Avatar
I've never seen Heave-To taught as the quickest way to stop a boat. I teach at a lot nonprofit and we teach it as the best way to stop the boat for a long period of time. That is also how I use it, we go hove-to if we want a lunch break, need to reef the main, or otherwise need a break.
Where I teach we use safety position (come up beyond close hauled, release sails) as a quick way to stop the boat, but not a way to stop it on a dime. We teach rudder braking/tight turns as a quick way to slow down the boat (especially while docking).
We've moved away from the Quick Stop/Jybe Around style of MOB to Figure-8. It is safer not to jybe in the conditions where you might have lost someone overboard. I'll have to try jackdale's version where you leave the sails tightly trimmed on a few boats and see how it works for me.
Alex W is offline
post #16 of 22 Old 02-13-2014
Owl
-OvO-'s Avatar
Just make sure you haul your crewmember aboard before you drift down overtop him and drown him under your boat.
-OvO- is offline
post #17 of 22 Old 02-13-2014
Old enough to know better
Originally Posted by capttb View Post
He was probably referring to the "Quick Stop" similar to heaving to.
Quick Stop - WMV
Interesting video. But that web page is awful, copyright 1999 to 2002?!?! requires Netscape?
miatapaul is offline
post #18 of 22 Old 02-15-2014
paulk's Avatar
We've found the Quickstop method to work fastest, though you do need the room to do the maneuver. Whatever point of sail you're on, tack and circle 'round. We've done this with the spinnaker up in 15 knots of wind, as well as with other sail/wind combinations. It puts the boat pretty much back where you were, ready to do something else. What you do after that - luffing, heaving to, dropping sails, picking up a MOB or a mooring, is up to you.
paulk is offline
post #19 of 22 Old 02-15-2014
jackdale's Avatar
Has anyone tried heaving-to with a self-tacking jib? Some monohulls (Hanse) and many multihulls have self-tacking jibs.
jackdale is offline
post #20 of 22 Old 02-16-2014
Yes, you need to prepare first, in Scandinavia you will find that self-tacking jib is used on more boats than just Hanse.
I have permanently rigged barber/inner/outer haulers on my self-tacking jib.
The way mine are rigged they have several uses.
  • Adjust the slot while sailing upwind
  • I can open up and while going downwind
  • It will prevent the jib from auto gybing when going DDW in lumpy sea
  • It is an easy way to backwind the sail
Some pictures
The barber hauler is attached to the ring around the 1:2 sheet, this way I have he pull going parallel to the track even with a partly furled sail.
The jib pulled closer to the center line.
I have installed pad eyes at the toerail for the low friction rings.
jackdale likes this.
knuterikt is offline
The Following User Says Thank You to knuterikt For This Useful Post:
jackdale (02-16-2014)
Stopping your boat mattt General Discussion (sailing related) 15 09-21-2013 08:18 AM
Stopping in the US with no visa 100fuegos General Discussion (sailing related) 18 06-23-2012 04:27 PM
Stopping along the way? lostatsi General Discussion (sailing related) 9 10-26-2010 12:43 PM
O'Day 28 - Dime Sized Hole in Bow crosenbaum O'Day 4 09-11-2006 10:58 PM
A DIME A DOZEN starcresttoo Boat Review and Purchase Forum 0 10-18-2005 07:36 PM
