Go Back   SailNet Community > General Interest Forums > Learning to Sail
Old 01-21-2006
ricccccc is on a distinguished road
explaining sailing terms
If there is any sea running, heave-to before going overboard. Once the boat is hove-to, it will create a slick to weather and a lee downwind, making it easier to work and climb back aboard. Can someone explain what slick to weather,and a lee downwind is. Thanks
Old 01-21-2006
Sailormon6 will become famous soon enough
The weather side of the boat is the side that is facing the wind. The lee side of the boat is the side away from the wind.
When the writer says there will be a slick to weather, he means that there will be an area near the weather side of the boat that will be calmer than the rest of the sea. The mere presence of the boat''s hull will have the effect of calming the wave action just to windward of the boat.
When he says it will create a lee downwind, he means that the boat''s hull will block the wind, and anything that is in the water on the lee side of the boat will be sheltered from the wind.
Apparently, the writer is suggesting that, if you have to go over the side to work on the boat for some reason while you''re at sea, you should heave-to, because, in that attitude, the boat will shield you, to a certain extent, from the wind and the waves.
Cats on Board slosharron Living Aboard 49 3 Weeks Ago 12:35 PM
sailing schools-vs-seat of your pants learning to sail tybeefolk Learning to Sail 25 02-16-2010 12:50 PM
SAILING IN THE AEGEAN OLYMPICYACHTS Chartering 0 11-20-2002 12:54 PM
SAILING IN THE AEGEAN OLYMPICYACHTS Chartering 0 11-20-2002 12:52 PM
ISAF Eligibility Requirements paulk Racing 4 02-05-2001 11:25 AM
