Need Rigging Advice - Page 2 - SailNet Community
post #11 of 11 Old 04-03-2014
Re: Need Rigging Advice
Yep on both my Halyards that is how I attached the line. On a small boat like ours there isn't a huge amount of tension on the halyard. Although in the pictures it looks like they are using it to attach the line to a big boat.
In terms of which line I would go with. It depends on how much money you want to spend. If money isn't a big concern I would instantly go with New England Ropes. It's probably one of the highest rated rope. For my climbing ropes I have purchased in the past I only trust New England. Just like anything you'll probably get people recommending all sorts of rope.
Because I'm a cheapskate I went with Cajun Ropes. After pricing them out it cost about 40% less than New England. I haven't had any problems with them yet but I'm on my first season. Someone else in the forums recommended them to me.
Edit: Oh! And if you want to try splicing the braided rope here is a great PDF created by NE Ropes. http://www.neropes.com/Resources/84906_NEROPE.pdf If you were going to try your hand at splicing I would probably order the line a little longer than needed in case you need to try the splice a couple times. In the guide it tells you how much line is required for the splice so you can judge how much extra to get.
Jhiggy is offline
The Following User Says Thank You to Jhiggy For This Useful Post:
jwing (04-18-2014)
Tags
mainsheet , o'day , rope , traveler , widgeon
A little rigging advice please Dauntless Brent Gear & Maintenance 10 09-09-2013 07:02 PM
New to forum, need advice about rigging manopeace Introduce Yourself 1 06-21-2011 01:50 PM
Advice Needed - New Rigging tedsouder Gear & Maintenance 19 11-19-2009 08:53 AM
Organizing the running rigging... need help and advice skrap1r0n Gear & Maintenance 11 04-24-2007 04:07 PM
Rigging Advice interceptor2795 MacGregor 1 04-11-2006 09:45 AM
