knockdown vs. capsize vs. broach - Page 2 - SailNet Community
 14Likes
post #11 of 21 Old 08-07-2014
Bristol 45.5 - AiniA
Re: knockdown vs. capsize vs. broach
Knockdown - not just wind, a large wave at the wrong time can have a lot to do with this (ask me how I know)
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #12 of 21 Old 08-07-2014
I think for a broach to occur the rudder has to stall if not the boat will simply round up. Burying the rail is not a broach. I have raced on boats where burying the rail does happen quite often. On these boats the stanchions and lifelines are removed, mostly for sheeting but a tertiary benefit is there is less drag when the rail is buried.
ScottUK is offline
post #13 of 21 Old 08-07-2014
Slayer's Avatar
One definition for the word broach is to break through the surface from below. I always thought when you broach while sailing you lose control of the boat because your rudder has lost its ability to steer. So maybe it is when you heel enough the rudder breaks the surface (hence the name "broach") and you lose control of the boat. I am not offering this as an answer, more of a question.
Slayer is offline
post #14 of 21 Old 08-07-2014
Minnesail's Avatar
A broach is the thing Johnny makes out of the weather report in Airplane!
Catalina 22
on a starboard tack
Minnesail is offline
post #15 of 21 Old 08-07-2014
The rudder stalling is the result of the broach caused by a spirited gust or if sailing DDW the boat can start to rock from side to side and the rocking can get more extreme to the point of losing stability where the boat rounds up and then becomes pinned. This can result in a gybed broach. Though I have experienced numerous broaches from these two causes, I have never had a gybed broach.
ScottUK is offline
post #16 of 21 Old 08-07-2014
Correction - I forgot doing it twice in a ten minute span at night during an offshore race.
ScottUK is offline
post #17 of 21 Old 08-08-2014
Cruising at a snail pace
knockdown - cry like a little girl
broach - scream like a little girl
capsize - water fills your mouth when you try to scream
chucklesR and rymerj66 like this.
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
post #18 of 21 Old 08-08-2014
Moderator
Jeff_H's Avatar
I was not going to weigh in on this but it does not seem like anyone has nailed this one in terms of the way that these terms are used in yacht design. This is not all that complex.
A knockdown refers to the rapid change in heel angle from a acceptable, normal heel angle to something beyind that point.
A broach refers to a rapid change in direction (yaw) that will usually lead to increased heel or perhaps a knockdown, but nothing in the definition of a broach requires either to occur.
A capsize is heeling to the point where stability switches from positive stability (trying to turn upright) to negative stability(the point at which the boat no longer tries to right itself.)
Jeff_H is offline
post #19 of 21 Old 08-08-2014
krisscross's Avatar
Done all three, but only in small dinghies, thank God.
Knockdown - strong gust of wind puts the mast and sail almost flat on the water. That happens a lot when you sail hard, but it is relatively easy to correct.
Capsize - the sail and mast are in the water and are staying there. You have to do all kinds of gymnastics on your dagger board to right the boat. Often you need help to get out of that pickle.
Broach - the wind and wave conditions create situation where the boat is uncontrollable and very fast on it's way to capsize. Very scary and unpredictable. Have a nice short prayer composed for just that kind of occasion.
Plato
krisscross is offline
post #20 of 21 Old 08-08-2014
Agree, broach is caused by loss of rudder control, usually by stalling (equivalent of airplane wing stall) the rudder. I think this can also happen on some boats when they are on the ear so far that there isn't much rudder left in the water.
So your carrying your spinnaker in too much wind, you head up a hair, the boat leans over a bit, you try to correct back down wind but the rudder is just dragging thru the water, it doesn't work, so the boat keeps heading up until the rail is in the water or worse, and you cannot fix it with the rudder. You gotta get rid of some sail or it just sits there on it's side...rudder is stalled, ineffective.
Or, your surfing down a wave, you get going real fast, you head up a little, the rudder stalls, and you lay over on your side or worse roll the boat over...like surfing in over a bar. Again a rudder stall, the rudder becomes ineffective.
At least that's what I thought.
capecodda is offline
Definition of Knockdown? CapnSantiago General Discussion (sailing related) 31 07-18-2010 12:27 PM
Great Cruise with a 10kts Broach! Vitesse473 General Discussion (sailing related) 2 07-02-2008 11:50 PM
Knockdown & Sinking In Oriental Joel73 General Discussion (sailing related) 17 07-01-2008 09:52 PM
Avoiding a Broach firehoser75 Seamanship & Navigation 7 07-17-2007 01:53 PM
Bristol 35C & recovery from knockdown otaga05 Boat Review and Purchase Forum 0 09-26-2006 03:25 PM
