Topping Lift - Page 2 - SailNet Community
 6Likes
post #11 of 17 Old 03-31-2013
Re: Topping Lift
Alex, Thanks for the info re:topping lift. I did know you could put bag in a sail using the topping lift to aid light air sailing. I am not set up the way your boat is, always good to know new tricks.
Quote: The wind and waver are always on the side of the ablest navigator.-Edward Gibbon, "The Decline and Fall of the Roman Empire"
luck66 is offline
post #12 of 17 Old 05-27-2013
Re: Topping Lift
It may be old, but it is still useful.
s/v Odyssey
Catalina 30
glassdad is offline
post #13 of 17 Old 11-06-2013
Re: Topping Lift
So I will ressurect this thread yet again with my .02 on using the topping lift for sail shape. I don't have one on this boat but did on my 16 footer.
That boat did not have a traveler and so I would use the topping lift to counteract the main sheet forces when going upwind in lighter airs. This would let me sheet the main in hard to the middle of the boat but then use the topping lift to lift the boom and avoid flattening the sail too much. It also moved the boom in another inch or two. Seemed kind of wrong but it did work for me.
tschmidty is offline
post #14 of 17 Old 05-03-2015
Gus
Gus's Avatar
Re: Topping Lift
Another good reason to have one in place, If you are sailing without a rigid vang and the mainsail halyard broke free you will love the topping lift. If it is rigged properly it will prevent the boom from dropping on your head or on your crew. just like when you see inexperience sailors dropping the main without following the proper procedures.
Gus is offline
post #15 of 17 Old 05-03-2015
Silversailor
Re: Topping Lift
Another advantage of a topping lift is that if it is properly sized it can double as a main halyard if the dedicated halyard breaks.
Silversailor
2006 Hanse 370e
South Haven, MI
Silversailor is offline
post #16 of 17 Old 05-04-2015
Re: Topping Lift
Its major function is to hold the boom up while you reef
harmonic is offline
post #17 of 17 Old 05-04-2015
4KSB driver.
SHNOOL's Avatar
Re: Topping Lift
Once again (as old as this thread is)... a topping lift serves 2 purposes, to hold the boom up when nothing else is, and to counteract the forces holding the boom down (for sail shape).
As others have said, a top lift adds complications (drag, and trailing wind disturbance) while sail is up, and some prefer a rigid vang or a boom kicker instead. These two devices ARE NOT a complete replacement for a proper topping lift, however, the biggest issue is merely while transitioning between sail up, and sail down (kicker doesn't provide enough upwards force to support leaning on the boom).. this is usually mitigated once the main halyard is moved from the head of the sail to the boom end.
I personally hated dealing with the topping lift, and would frankly prefer the boomkicker (as I've had 3 on 3 boats, removing topping lifts on each boat). But that's just my preference. The boomkicker must be used with a vang (boomkicker provides upward force, vang provides down)... a rigid vang usually includes a downward force adjustment along with upward.
These are preferences and are completely up to the skipper. Some even keep a top lift as well as a rigid vang or kicker. On a larger boat this makes some sense to me, especially if you aren't racing.
Steve in Idaho likes this.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
Topping lifts revisited PBzeer Gear & Maintenance 2 02-28-2004 04:02 PM
Topping lift PBzeer Seamanship & Navigation 11 02-19-2004 07:39 PM
hard vang means no topping lift? jbarros Gear & Maintenance 14 07-11-2003 08:43 PM
anyone using a boat lift? DuaneIsing Gear & Maintenance 0 01-03-2003 08:25 AM
