Blogs
Go Back   SailNet Community > General Interest Forums > Learning to Sail
User Name
Old 07-30-2006
Marlinspike Marlinspike is offline
Marlinspike is on a distinguished road
Newbie question regarding Seacocks
So... My Cape Dory manual specifies that all seacocks should be closed if the boat is to be left alone overnight or longer. The surveyor who showed me around the boat, and knowing I was new to larger boats, pointed out the scupper drain seacocks, noted that they were tie-wrapped open by the previous owner, and mentioned that these must stay open. This is contrary to the manual.
Thoughts?
Old 07-30-2006
GordMay GordMay is offline
GordMay is on a distinguished road
The Cockpit Drain and Automatic Bilge Pump Discharge (if fitted) Seacocks must remain open. All other seacocks should be closed when boat unattended.
Old 07-30-2006
camaraderie's Avatar
camaraderie camaraderie is offline
moderate?
camaraderie is a jewel in the roughcamaraderie is a jewel in the roughcamaraderie is a jewel in the rough
If you close the scupper drain seacocks...the cockpit can fill with water that has no place to go..eventually sinking the boat. Just make sure that the hoses which lead from the cockpit are in good shape and that the DOUBLE hose clamps at both ends are in good shape.
Sponsored Ad
Old 07-30-2006
sailingdog sailingdog is offline
sailingdog is just really nicesailingdog is just really nicesailingdog is just really nicesailingdog is just really nice
Also, many cockpit drain seacocks and bilge pump seacocks are actually above the waterline... so they're really not much of a danger of sinking the boat unless water is getting in somewhere else or they're closed.
If you're new to the Sailnet Forums... please read this POST.
Old 07-31-2006
nolatom nolatom is offline
nolatom will become famous soon enough
You might tell Cape Dory the manual could stand to be revised. They meant cabin through-hulls (head, sink drain, engine intake) but didn't say so. Cockpit scuppers are like deck scuppers, they have to stay open.
P.S. A lot of folks don't follow the manual. Betcha 3 out of 4 boats out there have open seacocks all summer.
Old 08-01-2006
SailinJay SailinJay is offline
SailinJay is on a distinguished road
Yep
My galley sink through-hull stays open all season.
Old 08-01-2006
So does mine, as does my head compartment sink thruhull, but both of these are more than a foot above the waterline.
The ones that need to really be shut are the ones that are BELOW THE WATERLINE.
Old 08-14-2006
yachtsea yachtsea is offline
yachtsea is on a distinguished road
Does anyone else still giggle silently to themself at the the word seacock?
vB code is On
heave to question robC25 Learning to Sail 2 07-24-2006 06:01 PM
stuck seacocks wumhenry Gear & Maintenance 22 07-14-2006 10:46 AM
Quick displacement question... kclaybrook General Discussion (sailing related) 19 07-13-2006 08:30 PM
A question to all boat owners Apollo18 Crew Wanted 6 12-31-2001 08:14 PM
Tayana 42 Fuel Tank Question jdmrussell56 Gear & Maintenance 2 07-29-2001 07:17 AM
Page generated in 0.5319 seconds (36.90% PHP - 63.10% MySQL) with 15 queries
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
