08-21-2006
Sounds like you're talking about tacking into the wind rather than jibing downwind. If so, are you doing it for comfort, or for speed? If speed isn't critical, and you have enough momentum to carry you through onto the new tack, you can leave the mainsheet alone, concentrate on getting the jib around, sheet it in as it fills on the new tack, then ease it out to a reach as you bear off, it'll keep you moving and turning too and then the main will fill itself.
If speed and more momentum are important, then you should trim both main and jib as you come up from a reach to close-hauled on the old tack, then tack 90 degrees (roughly) from close-hauled to close-hauled, then ease both main and jib as you bear off onto the reach.
