Go Back   SailNet Community > General Interest Forums > Learning to Sail
Old 09-08-2006
bkw bkw is offline
bkw is on a distinguished road
wind point / wind speed
which is in sync with the masthead fly. the apparent wind reading on the gage or the true reading on the gage ? how can the instrument tell the difference between apparent or true when it is part of the boat?
Old 09-08-2006
Everything your wind instruments sense is apparent wind. If the wind instrument knows your boat speed, it can use that plus the apparent angle to calculate what the true wind speed and angle is.
Old 09-08-2006
nolatom will become famous soon enough
Apparent wind angle is what the mast telltale shows. If your instrument also shows true wind, then something (a knotmeter or a gps?) must be giving the instrument your boat's speed and direction, which vector it "subtracts" from the apparent (upwind) or "adds" to it (downwind) to get the "true" speed and direction.
Old 09-10-2006
Be careful though, if you're using a knotmeter for the speed and direction of the boat, the "true" wind can be off if there is a strong current.
Old 09-11-2006
chrondi is an unknown quantity at this point
All these instruments should be properly calibrated if you need any degree of accuracy and reliability of the measurements! I think the angle reading is the most sensitive.
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
Close Hauled Tactics djakunda Seamanship 2 05-16-2003 06:10 AM
Ayrodynamics of Sailing ZachW. Learning to Sail 9 05-30-2002 10:41 AM
Wind Speed fishclan Seamanship 4 02-01-2002 12:09 PM
ideal wind speed? brucemcald Learning to Sail 9 07-21-2001 05:30 PM
