10-24-2006
Hmm... sounds like an interesting setup...however, the same problem applies to a dual vang setup that applies to normal preventers...if you do accidentally gybe, the vangs can put an undue strain on the boom and you may snap it if you're not careful... with a boom brake, the strain is not as bad, as the boom is still capable of moving, albeit at a relatively safe, much slower rate.
