12-07-2006
Originally Posted by Gary M
Many manufacturers made upgraded or modified versions of the same boat. A C & C 27 for instance had 5 variations starting with a MK I on up to V.
Hull speed is the theorectical maxium speed that a displacement hull can go. It is based on the water line length, the formula is the square root of LWL times 1.34.
A boat with a water line length of 25 feet will have a hull speed of 6.7 knots. Basically the fastest it will go unless surfing etc. Not all sailboats can attain their hull speed reaching or beating.
I recall being told the multiplier was about 1.3 for a "slow" boat, up to 1.5 for a "fast" one, leaving us to figure out which was which (though we pretty much knew). Nowadays boats have the Polar diagrams which supposedly figure this out for us.
I was also told that rather than being an absolute limit (in displacement mode), hull speed was the point at which any additional speed required way too much additional energy to be practical. For example, if a 20-knot destroyer took that 25-footer in tow, the hull would be going more than 7 knots (somehow), it wouldn't be practical under one's own power.
