Go Back   SailNet Community > General Interest Forums > Learning to Sail
  #11 (permalink)
Old 12-13-2006
T34C's Avatar
Thanks Courtney.
T34C has a spectacular aura about T34C has a spectacular aura about T34C has a spectacular aura about
Christy- First of all there were no quotes presented that were out of context, which you would know since you read the article. They were presented as "snippets" to provide timely documentary evidence for my point and to prevent the need to re-type the entire article. Additonally, I used it to provide a (very current) resource to help answer some of RAYs questions. It was NOT done to be offensive, merely an effort to point out that the technique that seems to works for you should not be construed as a blanket practice. (As you noted with your different techniques on 2 different boats.) One problem with what you are proposing is that while you are spilling some air from the leach up high when you ease the main sheet and "twist off" the top, you are adding more shape to the rest of the mainsail and counteracting your efforts higher up the mast. That's why a fractionally rigged boat would use the backstay adjuster instead of just using your idea everytime. ( I don't know what type of rig is on the boat Ray describes.) If while keeping the sheet tight you cannot depower the main suffeciently using the traveler, then you probably need to take in a reef.
"Choking off the slot" does not unbalance the rig, it decreases the sails effeicency which is precisely what you are trying to do when you are trying to depower. And while "choking off the slot" may not be considered "good sail trim" I would consider it good seamanship when talking about an unknown boat, with a rookie crew in need of maintaining control of their vessel when hit with conditions they had not prepared for.
Again, not intended to be offensive, just a different opinion.
  #12 (permalink)
Old 12-13-2006
RayMetz100's Avatar
learning to sail
RayMetz100 is on a distinguished road
Send a message via MSN to RayMetz100
I know it didn't have an adjustable backstay and I think the headstay was attached to the top of the mast.
Thank you for all the suggestions. Much of it is still too technical for me, but more exposure to the terminology and more sailing will help. It doesn't look like I'll be sailing this weekend, but hopefully I can go out again the Saturday before Christmas.
  #13 (permalink)
Old 12-14-2006
sailortjk1's Avatar
What a life..... Metz is going sailing on Christmas Eve!
Do you need crew? Wish that was me. We are high and dry for another 4 months.
Enjoy your Christmas Eve Sail!
(Well its Almost Christmas Eve, The day before the day before Christmas.)
(Close enough for me)
  #14 (permalink)
Old 12-14-2006
T34C's Avatar
Thanks Courtney.
Ray-
You are doing everything right by continueing to learn and then going out and applying what you learned. Keep doing what you're doing and have fun sailing.
  #15 (permalink)
Old 12-14-2006
BADG's Avatar
BADG is on a distinguished road
A great thread with substantive sailing discussion. These seem too few lately, we almost lost this one too but it came back. Thanks.
Which tack is faster? RayMetz100 Learning to Sail 5 12-11-2006 05:22 PM
Port tack overpowering steering enadler General Discussion (sailing related) 0 09-29-2006 07:18 PM
Rigging a tack for a drifter jonlgauthier Gear & Maintenance 2 09-14-2004 07:11 AM
Consolidating Gains on the Racecourse Dean Brenner Racing Articles 0 07-01-2001 08:00 PM
The New Racing Rules Dobbs Davis Racing Articles 0 04-04-2001 08:00 PM
