12-20-2006
Most sailing dinghies are generally less tolerant of mistakes than larger boats, unless you consider tolerance including getting dumped into the water and capsizing.
However, you will generally learn more about sail trim, sail balance, and such on a small dinghy or daysailer, than you would on a larger keelboat. as they are often more sensitive to such things.
