Sea Sickness - Cure? - Page 8 - SailNet Community
post #71 of 88 Old 03-21-2008
It's 5 O'clock somewhere
kccollbran's Avatar
I like the dill pickle idea, goes back to the vinegar.
kccollbran is offline
post #72 of 88 Old 03-21-2008
One of THOSE!
2Gringos's Avatar
I was on a small hi-res survey boat in the GOM once looking for a sunken boat, and we had a couple of the clients people on board who got sick. The cook had each of them take a tablespoon of the clear Karo corn syrup, and both of them were up and about shortly thereafter. Then he gave them some saltine crackers to chew on. They were at dinner that night.
I have suggested it to other people several times over the years, telling the story about how I watched it work that time, and they have reported similar results. I don't know if its the heavy, sweet nature of the syrup, or psychological if told it's a cure, but I have seen it work.
Expat Life in the Devil's Triangle:
2Gringos is offline
post #73 of 88 Old 03-21-2008
Saltine crackers are often good at doing the trick since they tend to neutralize the acid in the stomach and put some mass in there to help settle it.
sailingdog is offline
post #74 of 88 Old 03-21-2008
artbyjody's Avatar
A good article on the subject...[The Causes of Seasickness part 1]
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
post #75 of 88 Old 03-21-2008
Tangleberry-
FWIW, you're not supposed to cut the patches. If you do, they leak on the cut and can become less reliable. In order to adjust the dosage, you are better off putting a piece of foil/plastic/etc. under half of the patch, so it only makes 1/2 contact on your skin.
You can also get scope as "Scopace" pill form, which allows the dosage to be adjusted very easily, and kicks in faster especially if you allow it to dissolve under your tongue. (Goes to the blood supply very quickly.)
Interestingly I asked my doctor and my pharmacist about dosage versus body mass--and neither found any information about that. They suggested it is targeted for the brain, and since all brains are about the same size, that body mass might not matter much. (I still think dosage depends somewhat more on individual tolerance and response, so there's room for tailoring, just like with most meds.)
hellosailor is offline
post #76 of 88 Old 03-21-2008
Also, the cut edge will generally give a much higher dose rate than the uncut part of the patch.
post #77 of 88 Old 03-22-2008
Jim H's Avatar
I rather liked this thread about sea sickness at ybw--
Yachting and Boating World forums: What is the best for preventing sea sickness?
In particular, there are posts from someone who was part of seasickness tests in the 1970s. It's interesting that he thought himself relatively immune to seasickness until he was made violently ill by sitting in a static chair for 10 minutes-- the cause of the reaction was simply a moving projected horizon image on a hemispheric screen around him.
Jim H
London, UK
Aurora, a mighty Cal 20 (Portland, OR)
Southern Rival, a seasoned Rival 34 (Gosport, UK)
Jim H is offline
post #78 of 88 Old 03-22-2008
Zanshin's Avatar
JimH - I can believe that description about the method they used in the tests. The first time I did a jet simulator it was in an actual cockpit that was stationary, but surrounded by display screens (old CRT crappy resolution ones as well). I had over 2000 hours in planes at that time and was an aerobatics instructor so I was pretty cocky about being able to handle a military jet sim. They started me off at FL 300 and within 120 seconds I was about to lose my lunch from vertigo but fortunately I crashed the darned thing and that let my senses settle down again
So far I've not gotten seasick but I have a deep-rooted fear of getting incapacitated while alone on the boat. On one crossing I felt close to getting sick and had a couple of ginger cookies that worked really well.
Zanshin is offline
post #79 of 88 Old 03-22-2008
I haven't seen this mentioned in the thread yet, forgive me if I'm repeating someone though...
Just had some friends get back from Mexico, where they had gone out for a day fishing on the ocean in an open panga boat. One of the wives, after a couple hours in the swells, got seasick, and the guide quickly sliced up a lime and had her sniff it. She perked right up and didn't have any problems for the rest of the day.
I'd never heard of anyone sniffing limes before but thought I would throw it in the pot, both to see if anyone else has heard that one and for the more adventurous to try and report back.
ScuzzMonkey is offline
post #80 of 88 Old 03-23-2008
Cosmo Lean
We were two days out from Cape May enroute to Portugal when we received a Mayday from another sailboat heading to NY from the Bahamas. The skipper had a crew member who was unconscious from dehydration caused be seasickness. We relayed the Mayday to a container ship that passed us earlier that morning. They turned around and picked up the crewmember.
I'm not prone to seasickness, but on this trip I was sick five times. The worst case came when we were past the Azores where the gulf stream hits the European continental shelf as we passed thru a storm crossing our course. I felt like a water bug in a Maytag. I couldn't keep 7up or crackers down. I was beyond the prevention stage. I was seriously sick for several days. My skipper tried an old Cruising Club of America cure called Gatorade. This is not a commercial. I think any sports drink high in potassium to keep the heart going is worth a try. I started drinking just a shot glass full and progressed from there until I recovered after the storm passed.
Fwiw I think my first bout of mal de mar was psychological. Once I realized the boat wasn''t going to sink after the first gale I was okay. The strobe light later in the voyage was another cause. Everything in the boat got damp after awhile and the moisture caused the battery to give off a rotten egg smell. After I got rid of it I was fine until we were off Portugal.
paulvalles is offline
In Search of Sea Room Micca Hutchins Seamanship Articles 0 03-26-2002 07:00 PM
Sea Snakes Ralph Doolin Seamanship Articles 0 01-21-2002 07:00 PM
Sea Snakes Ralph Doolin Cruising Articles 0 01-21-2002 07:00 PM
