Question about Genoa Car adjustment - Page 2 - SailNet Community
post #11 of 48 Old 03-31-2007
Here .. Pull this
If you are just learning to use the genoa, and if your boat has a knotmeter (speedometer) then the easiest thing to start with is to go out on the water when the winds are not very strong. You will need a crewperson to help. Set the mainsail traveller car so that it is in the dead center of the boat and adjust your mainsheet so that the boat is sailing with very little heel, as close to the wind as you can get.
At this point it doesn't matter where your genoa car is (as long as the genoa is up and the genoa sheet is going through the block (pulley) on the genoa car). Start moving your car back and forth and look at your knotmeter to see what effect it has on your boat speed, also note what it does to your angle of heel, and how close your boat can sail into the wind. Don't adjust the mainsail at all, and have your crew maintain as steady a course as possible. Use your genoa to control your boat.
Then tack - without touching the mainsail - and experiment again on the other leg. Giu has explained the theory of it for you. Print his post and take it with you so that you can understand how it affects your boat. You may find a slight difference in adjustment is required between port and starboard depending on how true your keel is, how much weight there is on either side of your boat, and how evenly tuned your rigging is. Then again - you might not notice anything for a few years
Keep practising in various types of wind and water conditions. You will be surprised at how quickly you start to develop a feel for your boat. Expect to find a difference between the two Genoas, as the difference in size changes the location of the center of effort on the boat. Enjoy
Sailormann is offline
post #12 of 48 Old 03-31-2007 Thread Starter
my boat has absolutely no instrumentation yet, fun, I know.
At any rate, my cars lock into the rail with a springloaded plunger, so I cannot really adjust it on the fly, I have to set one when the opposite sheet is loaded. I can see the advantage of having them adjustable while loaded, and I may seriously consider something like that when I replace my running rigging and organize my lines, if it's worth it on a 25 footer.
skrap1r0n is offline
post #13 of 48 Old 03-31-2007
If you're going to race the 25' footer... yes, it is definitely worth it. If you're just going to cruise and day sail... maybe not worth the extra cost... Usually it can be retro-fit to the existing rails, by buying new genoa sliding cars and the block and tackle for the rail... but not always. In the case of a retrofit, it isn't all that expensive a move usually.
sailingdog is offline
post #14 of 48 Old 03-31-2007
Giu-
Do you have the white line marked for the different positions for the genoa at various reef points or for various sized headsails.
SD I have different sails so marking the line is not possible. I have the track marked with numbers, and a scale, that's what we use for reference.
Scarp. "coverting" the point by point genoa traveler to a adjustable one is easy and not so expensive.
You'll needtimes 2 off course)
1)a track stop (that you may already have, if you do just glue a rubber bumper to absrob the shock when the traveler comes aft
2) A track horizontal bolck or you can bolt a regular foot block, in front of the track
3) a line
4)jaw cleat
5) 1 hour of your time and time to remove the locker pin on traveler
That's all
Giulietta is offline
post #15 of 48 Old 03-31-2007
ASA and PSIA Instructor
Adjustable cars
Originally Posted by skrap1r0n
... any rate, my cars lock into the rail with a springloaded plunger, so I cannot really adjust it on the fly, I have to set one when the opposite sheet is loaded. I can see the advantage of having them adjustable while loaded, and I may seriously consider something like that when I replace my running rigging and organize my lines, if it's worth it on a 25 footer.
The ability to adjust the car under load is only of value for hard core racing, you can change the setting under sail simply by a brief luff up whichunloads the sheet...
If you want to improve the performance of your boat, get the car off the rail and onto a inner track to provide a closer sheeting angle. Such an angle will allow your boat to sail 3 or 4 degress closer to the wind, and provide a remarkable improvement in VMG (speed up wind). some race boats have adjustable cars, some don't, but NOBODY races with the genoa trimmed to the rail.
sailingfool is offline
post #16 of 48 Old 03-31-2007 Thread Starter
I have a rail with the car on it. I will get some pics today and post them of the set up
post #17 of 48 Old 04-01-2007
Helms ALee!
tenuki's Avatar
Giulietta I'm drooling over your boat and traveling genny cars.
No-one's mentioned that your head sail and main work together yet, just to make matters more complicated... ;P To see this play around as sailorman mentioned, but then once you have a handle on it start adjusting the main as well , experimenting with different traveler positions, etc. Watch the genny change shape...
I personally find the Annapolis book of Seamanship's section on sail trim (chapter 3) to be a good basic introduction.
An excellent exercise in general is to learn to sail your boat 'rudderless'. Lash it to the center of the boat and use just your sail trim to steer. Try to sail someplace complicated this way.
Ok, now you will be busy all summer just sailing in circles. hahahahaha.
tenuki is offline
post #18 of 48 Old 04-01-2007
Helms ALee!
tenuki's Avatar
everyone is gonna poop on me for saying this, but if the winds are light just hand the tiller to someone reliable and go up there sit or laydown and wank on the sheet right near the clew to check out all sorts of things.
I've been sailing catalina 25s a lot the last few years and they are nice little boats, I found the bigger head sail was required though. Do you have the tall rig? What are the prevailing conditions where you sail?
tenuki is offline
post #19 of 48 Old 04-02-2007
Helms ALee!
tenuki's Avatar
also, if you don't have a knotmeter installed just bring along a handheld GPS to check your speed. You'll 'need' one anyway to race (apparent speed/direction vs true speed/direction and distant waypoints, etc).
tenuki is offline
post #20 of 48 Old 04-02-2007 Thread Starter
No, I have the standard rig. I would like to have the tall rig and use the standard main on it so I could raise my boom and install a bimini. (I would also like to run my lines inside the mast, but a new spar isn't in the books anytime soon.)
Interestingly enough, I just picked up a Garmin Etrx Legend C this weekend. I justifie it in that it will work for both the non existent compass and the non existent knotmeter that my boat came with. I can also use it on my motorcycle, and in the car. Nice unit actually.
Finally, an LED Light with Some Warmth PracticalSailor Gear and Maintenance Articles 10 09-26-2007 11:39 PM
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
What is a Genoa? Kacper General Discussion (sailing related) 45 04-05-2007 03:23 PM
upwind Genoa trimming - lighter airs mikehoyt Racing 9 11-25-2004 03:32 AM
Adjustible Genoa Leads, Track & Teflon rick gleason Gear & Maintenance 5 11-28-2002 08:00 AM
