Question about Genoa Car adjustment - Page 4 - SailNet Community
post #31 of 48 Old 04-03-2007
A lot of the new mains on boats are loose-footed mains.
sailingdog is offline
post #32 of 48 Old 04-03-2007 Thread Starter
Hmm ok here is a dodger set up on a C25, but that make no mention as to what the rig set up is, standard or tall. one could extend the dodger back a tad to where it just clears the main sheet, I suppose...
Edit: I have seen main sheets rigged to where rather than extend back to the Traveller, they have a set up where they go from a single point on the boom to a point on the starboard and port side. Would it be possible to rig a setup like that forward (say, close to where the boom vang is attached) on the boom, or would the load be too much and create a possible point of failure?
skrap1r0n is offline
post #33 of 48 Old 04-03-2007
Skrap-
If the boom is currently setup for an end-boom mainsheet, it would be unwise to set it up for a mid-boom mainsheet, as the boom generally needs to be a bit heavier for a mid-boom mainsheet. Also, the leverage you need and the tackle size usually has to be larger as well. If you have a 4:1 tackle as an end-boom mainsheet, you may need to get a 6:1 for a mid-boom mainsheet.
post #34 of 48 Old 04-03-2007 Thread Starter
yeah, I think I am looking for something that just isn't feasable on my boat.
post #35 of 48 Old 04-03-2007
The Catalina 25 can be converted to a mid-boom mainsheet without replacing the boom. The people on the Catalina 25 forum can tell you how to do it. Their forum is at the following website:
Association Forum
Sailormon6 is offline
post #36 of 48 Old 04-03-2007
Helms ALee!
tenuki's Avatar
all the catalina 25s I've been sailing out of the club were modified from end boom mainsheet to put the traveler just in front of the companionway and I liked it better. Never seen one up as far as the boom vang attachment though.
sailormon6, where does the traveler go in the mod you are talking about?
tenuki is offline
post #37 of 48 Old 04-03-2007
Originally Posted by tenuki
all the catalina 25s I've been sailing out of the club were modified from end boom mainsheet to put the traveler just in front of the companionway and I liked it better....sailormon6, where does the traveler go in the mod you are talking about?
That's what I've seen, too. It isn't legal in class racing, but, if you keep all the old hardware and don't remove the old fittings, it can be re-installed in a few minutes. There's a photo and description at the following link:
Catalina - Capri - 25s International Association
post #38 of 48 Old 04-03-2007
Helms ALee!
tenuki's Avatar
Ah, I meant the other front of the companionway. lol. They were down on the step up to the companionway. Didn't interfere with the pop top any that way. The pop top is really important on those boats cause without it all that pretend interior space isn't real IMHO. Of course my Ranger 24 has even less space below, but hey, at least it's not pretending to be a big boat.
tenuki is offline
post #39 of 48 Old 04-04-2007
Here .. Pull this
the standard and the tall (I believe the hull is the same)
...actually, the tall rig has a deeper draft (the keel goes down deeper in the water) which is done to counteract the effect of the additional mainsail area...if a "budget-conscious" builder like Catalina adds the extra draft - you can be sure it's a fairly important thing...
(this is not a shot at Catalinas - I think they are decent boats)
Sailormann is offline
post #40 of 48 Old 04-04-2007
Tenuki-
You're thinking about mounting the traveler on the bridgedeck.. That's a pretty common location for it. A bit of a pain when you're trying to get in and out of the companionway under sail though.
Finally, an LED Light with Some Warmth PracticalSailor Gear and Maintenance Articles 10 09-27-2007 12:39 AM
Ladder question mcain Gear & Maintenance 14 08-03-2007 11:28 PM
What is a Genoa? Kacper General Discussion (sailing related) 45 04-05-2007 04:23 PM
upwind Genoa trimming - lighter airs mikehoyt Racing 9 11-25-2004 04:32 AM
Adjustible Genoa Leads, Track & Teflon rick gleason Gear & Maintenance 5 11-28-2002 09:00 AM
