Go Back   SailNet Community > General Interest Forums > Learning to Sail
Old 04-02-2007
Mick Young is on a distinguished road
Depowering Jib
Hi people, is it a natural way to depoer the jib by running the jib lead forward on a mast head rig without a furler or am I just being lazy and should I change the jib?
Keep it black side down
Mick
Old 04-02-2007
ianhlnd's Avatar
A little less cheek
ianhlnd will become famous soon enough ianhlnd will become famous soon enough
Change the jib, if you have to depower, probably need to reef, stay out of trouble and change.
Just checking in.
Where ya'll keep'n the wimmin 'round here?
Old 04-02-2007
I'd have to agree with Ian... If you need to depower, chances are likely that you really should have reefed a bit earlier...
The time to reef is the first time you think it might be a good idea...not doing so often ends up with the black side up....and you swimming.
Old 04-03-2007
Thanks guys, Where we are going for the eastes break there is a lot of land effects, and rather than changing and reefing I was wondering whether in those sort of conditions it was better just to depower than keep changing. The bank balance said no to a furler, so we still manually change, which I am more than happy about as it gives me the necessary experience in doing so.
Mick
Old 04-03-2007
GordMay is on a distinguished road
Take a look at SAIL Magazine's ”The Jib-trim Series” ~ by Michael Tamulaites
SAIL Magazine
Old 04-03-2007
Sailormon6 will become famous soon enough
Mick, the answer to your question depends on many variable factors. Each jib is designed so that it is efficient within a certain range of windspeeds. The problem is that the wind doesn't always cooperate by blowing steadily within that windspeed range. Wind blows in puffs and lulls. One moment you may be overpowered while beating to windward, and then you sail into a lull, and you may wish you had more sail area. When you're racing, you select the biggest sail your boat can carry the most efficiently for the highest percentage of the time. You accept the likelihood that the boat will occasionally be overpowered for brief periods of time during the strongest puffs, but those overpowering puffs might only be a problem 4-5% of the time. The rest of the time, the sail area will be just right for the ambient wind, or you'll be sailing off the wind.
The sail trimming techniques that you're talking about can help extend the useful windspeed range of a jib a little bit, through short-lived puffs, but if the puffs are stronger, or longer-lived, there is a point where you're better off to reduce sail area. Other factors to consider are the length of the race, the ability of your crew to make a quick sail change, whether your boat is rigged for quick sail changes, and how much of the remaining race will be sailed to windward. If the boat is grossly overpowered, and you have a lot of windward work ahead, my inclination would be to change sails, even in a fairly short race around the buoys, because the boat will perform so much better that you may well make up the time lost in changing sails as against all the other boats that are still struggling, grossly overpowered, with the bigger sails. If the boat is only overpowered a small percent of the time, or most of the windward sailing is behind you, then my inclination is to use sail trimming techniques to keep the boat on its feet during that small percent of the time.
Old 04-03-2007
Gary M's Avatar
Gary M is on a distinguished road
I believe you said move the jib lead forward to depower.
That is not how I would do it. To depower a jib you would want to move the lead back to flatten the foot and open up the upper leach. You would also get as much halyard tension as possible to flatten the entire sail. In general though I would change down, lighter head sails are easily damaged when carried in too much air.
It is much easier to depower a main by flattening it as much as possible and dropping the traveler down, that is the normal way to temporaily reduce heel.
Gary
Old 04-03-2007
CapnHand's Avatar
humble pie rat
CapnHand is on a distinguished road
Stated in another way, moving the jib lead back allows the top of the sail to twist, spilling air from the top of the sail where the heeling forces are greatest.
There are 10 kinds of people. Those who understand binary and those who don't.
Sailing Basics Steve Colgate Learning to Sail Articles 0 03-09-2003 07:00 PM
Sailing Basics Steve Colgate Seamanship Articles 0 03-09-2003 07:00 PM
Sail Trim Steve Colgate Learning to Sail Articles 0 05-10-2000 08:00 PM
Sail Trim Steve Colgate Seamanship Articles 0 05-10-2000 08:00 PM
Sail Trim Steve Colgate Gear and Maintenance Articles 0 05-10-2000 08:00 PM
