05-31-2007
Originally Posted by USCGRET1990
The airplane wing theory is correct! The back of the sail is a high presure area and the curved front of the sail a low presure area. Ice boats, because of such low resistance, can attain speeds of twice the wind speed. I used to have a pic of a small cat pulling a water skier, but can't seem to find it.
Actually, ice boats can generally travel at more than twice wind speeds. The airplane wing theory is only part of the solution... it only generally works on multihulls and iceboats, as most monohulls have too much drag to allow them to take advantage of the additional lift generated by the increased apparent wind.
