Winches - Page 3 - SailNet Community
post #21 of 45 Old 06-18-2007
Giu-
You really need to learn to draw better...
sailingdog is offline
post #22 of 45 Old 06-18-2007
Owner, Green Bay Packers
How'd we get back on to winches? We'd just got the topic turned on to wenches.(g)
Wm. F. Buckley, Jr.
sailaway21 is offline
post #23 of 45 Old 06-18-2007 Thread Starter
saurav16's Avatar
Send a message via AIM to saurav16
Gui,
I understand how to pull in a sheet by pulling on them with my hands. The wind was blowing to hard to pull the sheet in further so I tried the handle.
You seem rather tempermental in your posts lately, perhaps you need a vacation, or just take the danforth anchor out of your @$$.
saurav16 is offline
post #24 of 45 Old 06-18-2007
tdw
Super Fuzzy Moderator
tdw's Avatar
Originally Posted by Valiente
I'd heard Australian dating practices were primitive, but if you have to lash them down, they probably aren't your type of wench.
Unless they want to be tied down. Ms Wombat is sometimes fit to be tied but I fear that is not the same thing.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #25 of 45 Old 06-18-2007
Thanks Courtney.
Originally Posted by saurav16
Gui,
And next you're going to ask about the light in the fridge????
Don't get upset about the answers you get when you ask a silly question. Now, back to the WENCHES!
hunter Legend 37 Semper Paratus
Formerly - Tartan 34C Yawl
T34C is offline
post #26 of 45 Old 06-18-2007 Thread Starter
saurav16's Avatar
Its not a silly question, I am new to sailing and am posting on the "learn to sail" forum...
saurav16 is offline
post #27 of 45 Old 06-18-2007
tdw
tdw's Avatar
Gui,
but the drum just turned but the rope didn't jib sheet just slid, and didn't pull the roller furling at all
Certainly didn't sound like it from your first post in this thread, part of which is quoted.
It looks pretty obvious to me that all G was trying to do was to explain that which you appeared not to understand.
If a line around a sheet winch does not adjust the sail then either it is loose on the drum (add more turns), is running in the wrong direction (reverse it), it needs the help of a winch handle (use it) or the operator is a brain dead moron (no action applicable). Non self tailing , you will then need a cleat to tie it off to or a jammer of some description.. This presumes that you have uncleated the furling line and it also presumes the winch is not seized.
Were I Giu , I'd have taken the aformentioned Danforth and given your haemorrhoids a tickle or two, inserted flukes first.
Twit.
― Terry Pratchett.
tdw is offline
post #28 of 45 Old 06-18-2007
tdw
tdw's Avatar
Do you know that it goes out when you close the door ? Had to remove all the shelves and groceries to make enough room to get in but yep, it did go out when Ms W closed the door on me. Not as comfortable as a nice warm burrow either.
Now, bring on them wenches. Mmmmmm, a pair of two speed self tailing wenches. I Like the sound of that.
― Terry Pratchett.
tdw is offline
post #29 of 45 Old 06-19-2007
Saurav16-
Since a winch depends on the friction between the line and the winch drum to work—it is important that the line be tightly wrapped around the drum as possible. The more wraps you have, the better the grip of the rope on the drum, since you're increasing the surface area in contact with the drum. On a self-tailing winch, the self-tailer automatically tightens up on the line as you turn the winch handle. On non self-tailing winches, it is up to the person tailing the line to add tension to the line. If you don't do this—the winch will just spin...and not actually move the line.
Try putting your hands around a rope but not grabbing it and see how well you can pull the rope—same idea—a winch can't pull the rope without grabbing it...
IMHO, Giu was honestly trying to answer your question... he's a good egg, if a bit soft-boiled.
T34C— IMHO, you're really not contributing... this is a learn to sail forum, and it was an honest if somewhat worrisome question. IMHO, common sense dictates that if you're trying to use a winch to pull on a line... you should probably pull on the line while using the winch....
post #30 of 45 Old 06-19-2007
OK...now you've done it....
Don't you know that you NEVER bring the word A-N-C-H-O-R to your thread????
Don't you know that Craig Smith and Allan Poiraud have their browsers on "stealth" mode, lurking for the word A-N-C-H-O-R and every time their computers detect the word, they come in and start their A-N-C-H-O-R fight thing??
Do you think your nice thread deserves a death like that?? do you??
By the way, I have a CQR, but its only to fool people..I don't really use it that much.....
Giulietta is offline
ISO advice re sizing winches brainstormers Gear & Maintenance 0 07-09-2004 07:03 AM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
