Go Back   SailNet Community > General Interest Forums > Learning to Sail
Old 06-22-2007
seapadrik is on a distinguished road
Which side of the lifeline/stanchion to run sheets
Newbie question here.
I am getting confused when running the port and starboard sheets from the clew of my headsail back to the cockpit. On one hand I think that if I keep the sheets outside the lifelines/stanchions until returning to the block/pulley in the cockpit it will make it easier for the head-sail to go over the lifeline when underway. However, if I rig it like that I notice when I change tack the slack sheet is now draped over the top of the lifeline.
What is the correct method? Am I screwing this up? Thanks
Old 06-22-2007
mpraca's Avatar
Zingaro
mpraca is on a distinguished road
Most boats have tracks on deck along which a a fairlead is positioned depending on the sail size. The sheet goes through that fairlead before going to the winch by the cockpit.
Some boats have those tracks on the rail, and the sheet is outside the lifelines but more commonly the tracks are inboard and the sheets run inside the lifelines. Maybe your boat does not have these tracks, since you mentioned a block by the cockpit. If the block is not on the rail I think the sheets should run inside the lifelines.
Z
ngaro
_^_____
Oh salsus mare!
quantus vestri salis
est lacrima Portucalis
Old 06-22-2007
JimsCAL's Avatar
JimsCAL is on a distinguished road
The sheets should be inside the lifelines. This is necessary to be able to pull the headsail in tightly when going upwind. When reaching or running the sheet will lay on top of the lifeline - not a problem.
Old 06-22-2007
T34C's Avatar
Thanks Courtney.
T34C has a spectacular aura about T34C has a spectacular aura about T34C has a spectacular aura about
Depends on the boat and where the tracks/blocks are located. Either answer could be correct depending on the boat.
Maeven
Tartan 34C Yawl #282
Anything-sailing.com
Moderator
Old 06-22-2007
bestfriend's Avatar
Hitchin' a ride
bestfriend is a jewel in the rough bestfriend is a jewel in the rough bestfriend is a jewel in the rough
I am guessing that you are talking about the fairleads that clamp on to the stanchions? Most of the time those should go on the inside. But don't go to far forward with them. If you draw an imaginary line perpendicular to the leech extending from the clew, the sheet line should not drop below that angle.
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
Old 06-22-2007
Seapadrik-
It would help if you said what kind of boat it is...since the group here has had experience with many different boats, and might know it. Generally, unless you have a fairly unusual setup, the sheets are run inside the lifelines.
Old 07-07-2007
wumhenry is on a distinguished road
same question
Seapadrik-
I sail a Bristol 29.9, and the fairlead track is on the toerail. I have been running the sheets outside the lifelines, but should I try it the other way?
Old 07-07-2007
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
Yes, you should. The windward sheet should be slack; if it drapes across a lifeline it's ok. The sheets inboard will allow you to point higher. When running there is much less strain on the sheets ans some contact with the lifelines will be acceptable. You'll probably re-position your fairlead so as to eliminate it anyway in pursuit of sail shape. I'll bet you're having trouble tacking smoothly with the sheets led outside the lifelines. Yes?
Wm. F. Buckley, Jr.
Old 07-07-2007
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
I run a 135 mostly so I run the sheet outside, but I guess it would depend on the size rag you're using, a 110 or 90 could be run inside
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 07-07-2007
PalmettoSailor will become famous soon enough
On My boat (32' Oday) we have a 140 genny and the sheets are inside.
Same deal on the Tartan 40 I crew on, but depending on condtions we may run a second set of sheets outside the lines to blocks on the toe rail and barber haul the headsail keeping the slot between the main and the headsail open. Probably more trouble than its worth for a cruiser, plus it would be difficult unless you had secondary winches as on the Tartan.
I think its more common to see boats designed to have the sheets inside of the lifelines.
Alternator Side Loading Problem Mithril Gear & Maintenance 5 06-24-2006 11:59 PM
Sailing Basics Steve Colgate Her Sailnet Articles 0 03-09-2003 07:00 PM
What to Do When You Run Aground Sue & Larry Her Sailnet Articles 0 12-18-2002 07:00 PM
Spinnaker Takedown Basics Dean Brenner Racing Articles 0 04-28-2002 08:00 PM
