07-03-2007
You could, but the boat probably would not be balanced properly, since it will want to head downwind... If you fall off, that would be bad.
IMHO, it might be better to sail with just the main sail, since that will tend to turn the boat into the wind, rather than have the boat run off. If you should fall in, the boat will be easier to get to if it is just sitting there in irons, rather than if you have to chase it.
