Go Back   SailNet Community > General Interest Forums > Learning to Sail
Old 07-31-2007
Everlong is on a distinguished road
anchoring.....
any stickies on sailnet on anchoring? Just curious....
i picked my marina because of scenery, and ease to get to open water without going through channels etc.... the main problem with the location is anchoring, there isn't too many beaches where i could just "drop it" and stay overnight. All the bottoms are mostly rock slabs, or "beaches" consisting of 4" stones... My main problem is what type of anchor to use to get a good night sleep without worrying about drifting etc...
The boat is a 26 foot c&c and i have two danforths on it...
Not really interested in donating any of these What to use? am i doomed?
I'm located in Lion's Head, Ontario, Canada.
Any info would be appreciated, links etc...
Old 07-31-2007
hellosailor's Avatar
If the search engine doesn't lead you to the many discussions of anchoring, look on the web. There's plenty of information out there, including heated debate about what's best.
Generally, if you can lift an anchor, it's not big enough. < g >
It helps if you learn to sleep with one eye open while at anchor. Or at least, a good anchor position alarm on the GPS.
Old 07-31-2007
I'm not a big fan of Danforths as a primary anchor. They don't reset well in many cases of shifting current or wind direction, are horrible in many types of bottom, other than sand or mud, and tend to foul fairly easily in the case of a wind/current shift.
I'd recommend a 10-15 kg next generation anchor--a Rocna (which is what I have); Bulwagga; Spade; Buegel; or Manson Supreme.
Old 08-01-2007
hellosailor: thanks for advice lol...
Sailindog: Rocna? even for rocky bottoms? or should i use a combination of some sort?
Old 08-01-2007
rocky bottoms are problematic for most anchors, and generally, the best thing to do with rocky bottoms is have a really heavy anchor.
I didn't recommend the Rocna specifically, since that would probably trigger a response from Alain or Craig... but I do like my Rocna. My major complaint with it is how much muck it brings up each time I've used it. It usually has 15-30 lbs of bottom on it when it comes up. UGh... a major cleaning mess.
On my boat (a 28' 4000 lbs trimaran) I have a 15 kg Rocna as my primary anchor and a 14 lb. Danforth as a kedge. One of these days I'm going to get a better kedge anchor, maybe a Delta, but haven't done so yet.
Old 08-01-2007
Gary M's Avatar
Gary M is on a distinguished road
Winfield Basin ?
Run up to Winfield basin it is sheltered and a nice anchorage. Anchoring on your side of the peniusula is pretty exposed and not something I would be too keen on. Generaly it is good to get in behind an island etc.
If you have two Danforths you do need to get another style. They work pretty well in mud, sand and clay if you can get them to set properly and no wind or current shifts but for rock you do need something heavier.
Gary
Old 08-01-2007
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
Many people reccomend a CQR / Claw anchor specificaly for anchoring in rocky bottom areas. As discussed / debated in another thread, these can be used in tandem with your existing danforth to increase the holding power.
Old 08-01-2007
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
Here we go again . . . Mr. Smith should be chiming in soon.
True Blue . . .
sold the Nauticat
Old 08-01-2007
camaraderie's Avatar
moderate?
Delta, Spade,Rocna,Manson, CQR,and Bruce are all much better choices for rocky bottoms than Danforth. Read the threads & you may find one more appealing than another. You need to penetrate and hold OR hook in such circumstances. Learn about rigging a trip line too if you want to get your anchor back!
Old 08-01-2007
Brezzin's Avatar
Brezzin is on a distinguished road
Send a message via AIM to Brezzin
A lot of yacht clubs and sailing groups run swap meets. This is a great place to pick up anchors cheaply. Also if you know any divers, ask them to keep an eye open for a "donated" anchor. Tell them you'll buy it from them.
I was diving on wreck in block Island sound last year and I picked up a brand new 35 lb delta and about 120 feet of three strand and 20' of chain all new. I sold it for $150.00 at a swap meet. Chances are that divers have donated anchors in their garages already. All the wreck divers I know have a real hard time leaving anything of value behind.
Dave
s/v "eclipse"
Mystic CT
2007 Hunter 49
To Have and To Hold (anchoring) GoodOldBoat Good Old Boat 6 12-28-2010 05:50 AM
Anchoring Control Liza Copeland Learning to Sail Articles 0 05-05-2003 08:00 PM
Anchoring Control Liza Copeland Seamanship Articles 0 05-05-2003 08:00 PM
Anchoring Control Liza Copeland Gear and Maintenance Articles 0 05-05-2003 08:00 PM
Anchoring out Differences Micca Hutchins Seamanship Articles 0 08-31-1999 08:00 PM
