Go Back   SailNet Community > General Interest Forums > Learning to Sail
Old 08-10-2007
saurav16's Avatar
saurav16 is on a distinguished road
Send a message via AIM to saurav16
Adjusting cars for jib sheet
I am confused when do I adjust the cars on the jib sheet. When should I move them towards stern and when should I move them towards the bow?
Old 08-10-2007
If the foot of the jib is loose, adjust the cars aft, if the leech of the jib is loose, adjust the cars forward.
If the bottom jib tell tales lift first, the fairlead generally needs to be moved aft, and if the top jib telltales lift first, the fairlead needs to move forward.
Old 08-10-2007
saurav16's Avatar
What do u mean by loose? When wind is filling the jib its all pretty tight.
Old 08-10-2007
The sail should be tensioned fairly evenly between the foot and the leech. If it isn't you'll generally notice... if the foot has more tension, the leech may flutter or flog a bit. If the leech has more tension, it will generally cup and ruin the clean airflow over the jib.
Old 08-10-2007
uspirate's Avatar
Trim for Sail
uspirate has a spectacular aura about uspirate has a spectacular aura about uspirate has a spectacular aura about
Good info SD! just a quick note: my kid pulled my telltales out, he said "dad, there was a piece of string stuck on the sail but i got it out" lol kids, gotta love em.
signature
BJ & Nimfa
S/V Flocerfida
Old 08-10-2007
LOL... at least the kid only got the lowest one... I hope...
Old 08-10-2007
Saurav,
Here you go...from uncle Alex....
The genoa traveller normally dictates how much twist and Bag will the genoa or head sail have. Full forward will give you more bag, make the sail “more rounded”, and will normally give you more power, as the sail “camber” increases, causing more lift. Moving the traveller back will flatten the sail, making it more aerodynamic for stronger winds and or narrower pointing angles.
Think of it as a plane wing when its landing, they lower the flaps in the rear and the slats in the fron to make the wing have more lift, but speed is lower, if the plane was to fly faster that configuration would create too much drag.
To fly fast, the wing is really flat.
Traveler forward sail has more bag or curvature, traveller aft sail will be flatter.
How to set it, really comes with experience, as the wind picks up, or you point higher, a head sail with too much camber or bag (traveller forward), will stall sooner and start flapping, so as the wind picks up or you close the angle to the relative wind, you will need to flatten the sail (move traveller aft).
Start with the traveller in a central or mid position, in a position that is neutral. Then move the traveler forward, if you look at the sail, its bag moved towards the outside, this gives it more power, but less ability to point.
Then move it back and the sail becomes flatter, you will point higher, but have less power.
If the winds are weak, set them forward, slowly and see how the boat behaves, keep noting what happens when you move them, its intuitive.
If the winds are stronger, move the traveler back.
In light winds or when off the wind its normal to have the traveller forward, to increase twist on the sail, and as the wind picks up you will need to move the traveller backwards.
My traveller is controlled from the cockpit, we use genoa travel control when tacking (in some conditions), to help power the sails and accelerate the boat after it losses speed from tacking.
What we do is just before tacking we see where the traveler of the windward side is, move it forward if possible, then tack, the boat looses speed, but in this condition, with the traveler forward, the sail has more power, it helps accelerate, imagine 1st gear on a car, then as the boat accelerates, we start bringing the traveler back, and the genoa sheet also, and now that the inertia is gone, we shift 2nd gear....
So..start neutral, move forward for light winds and off the wind, and move backwards for strong winds and pointing higher.
If you have tell tales, start close hauled, and with traveler neutral (if you divide your luff in two, you found the middle of your genoa, the neutral position is one where the line between the middle of the luff, athe clew and the genoa car area straight line). Look at tell tales the ones where the wind is blowing from must be horizontal. Look at the bottom tell tale, if it is shaking and not horizontal, move the traveler aft, if the top one is shaking, move the traveler forward. Simple. Tell tales are best to get the car in right position.
Then there is halyard tension, backstay tension, shroud tension... bla bla bla .....comeback after yoiu found where to put the traveler we will explain the rest....
Here's a pic of my traveler with remote adjustment. Good very very good...
The next photo shows that under normal use, as you pull the sheets, the traveller wants to move back, we allow that to hapen by releasing the traveler control (that only pulls the traveler forward). Its the white rope that is loose
I really have to go, I am sure someone else here might help with better terminology.
Bye
Old 08-10-2007
uspirate's Avatar
Trim for Sail
youre not gone yet? does that decal on your boat mean no drag queens and no bums?
signature
BJ & Nimfa
S/V Flocerfida
Old 08-10-2007
(Pirate...Nope...have to finish a report...almost gone...almost)
Saurav, here is a drawing that shows the "neutral" position...just in case I confused you.
Old 08-10-2007
He doesn't like people with combat boots or stilleto heels on his teak decks for some reason.
Trimming Your Asymmetrical Spinnaker sandygoodall Seamanship Articles 14 03-31-2010 09:27 AM
Reading Flow and Making Adjustments Tom Wood Learning to Sail Articles 0 09-23-1999 08:00 PM
Reading Flow and Making Adjustments Tom Wood Seamanship Articles 0 09-23-1999 08:00 PM
Reading Flow and Making Adjustments Tom Wood Gear and Maintenance Articles 0 09-23-1999 08:00 PM
Reading Flow and Making Adjustments Tom Wood Cruising Articles 0 09-23-1999 08:00 PM
