09-09-2007
Generally, on a dead run, or almost a dead run, the telltales on the sail mean virtually nothing. The wind isn't moving across both surfaces of the sail in a laminar flow. It's just pushing on one surface of the sail, driving the boat downwind like a leaf on a pond. As you steer the boat increasingly upwind, from a run to a broad reach to a beam reach, at some point, the wind begins to flow across both sides of the sail in a laminar flow. I can't describe exactly at what point that happens, because it depends somewhat on how your boat is rigged and how you sail it, but when it happens, then the telltales on your sails start to lift and can be used to help you trim your sails again.
