10-14-2007
Yesterday was crazy windy on the Sound, so I don't doubt folks were heeling quite a bit. If your boat was properly designed (and I bet it was), it will not tip. It is what we call "tender" though, meaning she will be easy to make heel over, maybe as far as 20-25 degrees. This will feel like you are about to be dumped out of the cockpit. Don't worry, you won't be. however, Sailorman is right, the only way to learn this is to be out there and to get comfortable. Be assured that it will take more than wind to knock down your boat (a combo of strong winds and well-placed wave action is usually necessary), and even then, she should right herself. Anyway, this is supposed to be fun. If you are worried about the wind being too strong, there are a bunch of things you can do to ease your stress: put a reef in while still at the dock; only hoist your main; if you don't have roller furling, get it. It not only elminates the need to go forward in a blow, many sailors will also only unfurl the genny/jib in strong winds. Quicker than you think, you will become comfortable in a range of conditions. Btw, I didn't check because I couldn't go out yesterday myself, but I would have been surprised if there weren't a small craft warning on the Sound yesterday. It was blowing at least twenty steady here, twenty miles inland, gusting even higher. I don't take my Oday 23 out in weather like that unless I have a crew aboard that knows what they're doing and likes rough weather.
