11-11-2007
This is a rough guideline, but will vary depending on the specific boat and sails you have
Light air: everything up...
Force 4: Genoa, staysail, main
Force 5: Yankee, staysail, main
Force 6: Staysail, single reef main
Force 7: Staysail, double reefed main
Force 8: Storm staysail, trysail
Force 9: Bare poles... and pray.
When running, you can have more sail up, but don't put up too much more than you'd use for sailing a reach or upwind in the same conditions, since an accidental gybe will knock you down pretty badly otherwise.
Most cutters will balance better if the storm staysail is balanced by a trysail.
I hope this helps.
