Go Back   SailNet Community > General Interest Forums > Learning to Sail
Old 12-27-2007
sab30's Avatar
sab30 is on a distinguished road
Crossing VTS Traffic/shipping lanes
Is there a protocol for crossing VTS lanes? Some I know issue a securite' but others just watch for traffic. Specifically the Rosario straight in Pacific NW which can be up to 5 nm across. Do you contact Seattle traffic service or issue a securite? I am aware of VTS zones but no one has ever explained if there is an exact protocol?
Thanks...
Old 12-27-2007
kiprichard's Avatar
kiprichard is on a distinguished road
I've crossed Rossario and most other straights and passes in the area dozens of times (except Puget Sound) and have never used securite' or contacted Seattle trafic, nor have I ever heard anyone else on the radio do so just for crossing. But I think I would if visability was restricted.
Old 12-27-2007
Cross as close to perpendicular to the VTS as possible, to reduce your transit distance/time as much as possible. You should contact the VTS control to let them know you're there.
Old 12-27-2007
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
I concur with sailingdog's advise. VTS reporting has the advantage that the VTS operators will be aware of traffic well out of sight that may be closing rapidly. That traffic will also be aware of your presence and intentions via the VTS operators. Should you encounter difficulties of any sort, you'll have the advantage that VTS and concerned traffic has already been on the lookout for you. Securite' by all means in fog-I rec. every fifteen minutes depending on situation. I'd also rec. not being in a traffic seperation zone in fog if it can be avoided.
Wm. F. Buckley, Jr.
Old 12-30-2007
tenuki's Avatar
Helms ALee!
tenuki will become famous soon enough
Everything you need to know about Puget Sound VTS is at their website, summarized nicely in this pamplet and this flyer.
There are specific VTS channels you can monitor for different areas of the sound - 14 south of possession point and bush point, 5a north of there. Note that channel 16 is specifically _not_ VTS traffic and many commercial vessels do not monitor it. I believe Seattle asks that you just listen, not notify, although in fog I would probably notify. Everything is detailed in those two links.
I cross the VTS all the time, but I primarily day sail in a portion of puget sound where the VTS traffic can be spotted way ahead of time and the lanes are pretty narrow. Those big ships move helluva fast, if I can see one at all I stay out of the VTS usually.
member
Old 12-30-2007
sab30's Avatar
Thanks a bunch tenuki...actually crossing west coast of Cypress Isl to Peavine Pass so not very far..at think the lane is less than 1nm at that point....
Sab30
Old 12-30-2007
sandsailor's Avatar
capt'n
sandsailor is on a distinguished road
TENUKI ,thats not your boat is it ???
Sand Sailor
Old 12-30-2007
tenuki's Avatar
Helms ALee!
hahaahahaha, nope. stupid power boater, not my pic either, off the coast guard site.
member
Old 01-12-2008
jrd22's Avatar
Courtney the Dancer
Good advice and information Tenuki, thanks.
Sab-when crossing from Cypress to Peavine, if you are at the south end of Cypress it's about 2NM over to the Blakely shore. Tugs and ships heading southbound can be hidden by the north end of Cypress and if the current is ebbing hard they can be on you in short order. When the current is ebbing a local trick is to go north on the inside (Cypress side) of Strawberry Is., there is a reverse current there that will help you out and then you can cross almost straight over to Blakely/Peavine. I have never heard anyone issue a Securite in Rosario except in fog, and rarely even then. Be aware that the Washington State Ferries use Peavine Pass occasionally (they use it as a back up route during high winds), which can be a real shock if you turn the corner to the south riding a nice 4K current only to see a monster ferry heading your way!
John
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 01-12-2008
That boat is probably resting nicely on the bulbous bow. I do not think he was successful at cutting off the evil spirits. btw, that was a very, very slow speed collision.
Wm. F. Buckley, Jr.
Safest Route & Timing for Transatlantic Crossing? LaurenAndHeather General Discussion (sailing related) 19 02-28-2010 04:18 PM
Crossing the Bar into Rock Hall wbickle Chesapeake Bay 34 12-24-2007 01:17 PM
Crossing a Harbor Bar John Kretschmer Seamanship Articles 0 09-25-2002 08:00 PM
Good Lanes and Bad Lanes Brad Read Racing Articles 0 04-25-2001 08:00 PM
The First Ocean Crossing Sue & Larry Cruising Articles 0 01-16-2000 07:00 PM
