Blogs
Go Back   SailNet Community > General Interest Forums > Learning to Sail
User Name
Old 04-15-2008
rchiare1 rchiare1 is offline
rchiare1 is on a distinguished road
Question Spinnaker terminology and funchion
I have a 1998 CP16 that came with a cruising spinnaker.
I've yet to fly it, but in looking it over I find there is a 5" disc of white material sewn into the belly of the sail about 6' below the head of the sail. There is one disc on each side of the sail and each disc has a loop of fabric that would accept a line running vertically the lentht of the sail.
What is this disck called and what is is it's function?
Old 04-15-2008
Faster Faster is offline
Just another sailor
Faster will become famous soon enoughFaster will become famous soon enough
Sounds like a "bellybutton" for a take down line.
Does this sail stow into a sock or tube on deck? If so, the take down line would lead through the sock from the cockpit, out the front of the sock and up to that attachment point on the sail. During a takedown the tack , sheet and halyard are released and the sail sucked into the sock with the take down line.
Perhaps that's what you're looking at. I'm not familiar with that boat design.
EDIT: just took a look at what a CP 16 is - you probably won't have the sock/tube, but the take down line can still be used if you don't have a snuffer, or if you have difficulty dousing the sail without it.
Boating in BC waters since the '60s, sailing since 1981.
Currently on our 5th boat, a 1984 Fast/Nicholson 345.
Old 04-15-2008
nolatom nolatom is offline
nolatom will become famous soon enough
Faster's right, you can rig a line to these, they make the sail a little easier to take in since you're collapsing it from the middle.
But if you don't want to rig two extra lines to tangle with your pole (it's a symmetrical spin. with a pole?) just take it down the old fashioned way--let the pole forward, ease out the guy while you grab the clew on the sheet end and gather the whole foot in your arms so the chute is collapsed in the blanket of the main. Then someone lets the halyard off gradually as you stuff it into the bag, turtle, cockpit, cabin, or whatever.
If it's an assymmetrical "Gennaker", tacked down to the bow, essentially same deal. Main thing is to get it blanketed by the main, so it's not drawing while you're trying to douse it. Then your job is easy, it's just cloth, with no force on it.
Apologies if you already know all this. But it is the "Learning to sail" topic.
Display Modes
vB code is On
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
