Blogs
Go Back   SailNet Community > General Interest Forums > Learning to Sail
User Name
Old 05-21-2008
eMKay's Avatar
eMKay eMKay is offline
eMKay is on a distinguished road
Spinnaker with sock...
I have this:
It has a short line and a plastic u-shaped thingy attached to the tack, two long lines attached to the clew, the head is up in the sock of course. On the boat there is a block on the port side of the bow pulpit, and two stand up blocks near the stern, one on each side. Now, I know the head gets attached to the spinnaker halyard, and the sock hoisted. The P.O. showed me how to work the sock, but I forgot what he told me about where everything else attaches.
Mike
Siren 17 #1094 (first boat)
O'day 192 #488 (second boat)
Old 05-21-2008
Faster Faster is offline
Just another sailor
Faster will become famous soon enoughFaster will become famous soon enough
It almost looks like he added a block to the pulpit that may have been intended for the tack line.... but I'd suggest you not use that if so.
You can attach the tack line to the same fitting for the jib tack, mount a block there and run the tack line through the block and back to somewhere within reach of the cockpit. This will allow you to raise and lower the tack of the sail as you vary your apparent wind angle (lower closer to the wind, higher as you bear off)
The plastic thingy attached to the tack (corner marked "T") is meant to go around the forestay with a furled headsail as the support for the tack. These collars are pretty standard on these sails, but some prefer to fly the tack free off the deck as you can get more projection that way as you go deeper downwind. You can probably look into that once you get the hang of this sail.
Otherwise, the sail attaches pretty much like a headsail, tack to the bow, sheets aft to the cockpit. Your spinnaker halyard should lead fairly and be above the forestay so that you are not chafing the halyard on the exit box in the mast or the headstay.
The lazy sheet should also go around in front of the headstay so you can gybe the sail in front of the boat.
Enjoy!
Boating in BC waters since the '60s, sailing since 1981.
Currently on our 5th boat, a 1984 Fast/Nicholson 345.
Old 05-21-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Originally Posted by eMKay View Post
I have this:
The line is a tack downhaul and the plastic thing is a tack sleeve that is designed to go around a furled headsail usually, and allows the asymetric spinnaker to work much like a oversized genoa. The ATN Tacker is a commercially sold version of that plastic cuff.
The two long lines are the sheets, and they go around the front of the forestay, and the asym is basically gybed around the outside of the forestay.
Probably for the tack downhaul.
for the asym spinnaker sheets.
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
Old 05-21-2008
pfatyol's Avatar
pfatyol pfatyol is offline
Swansea, MA
pfatyol is on a distinguished road
What about the Sleeve control lines?
Patrick
S/V "Fat-Kat"
C&C 32, Hull #237
Mt. Hope Bay
Old 05-21-2008
eMKay's Avatar
Those I have figured out.
Thanks for the info guys!
Mike
Old 05-21-2008
Plumper's Avatar
Plumper Plumper is offline
Sailor
Plumper is on a distinguished road
Everyone has mentioned that the sheets go ahead of the forestay but have failed to point out that there are two ways to do that. One way is between the sail and the forestay and the other way is ahead of the sail. Putting the sheet between the sail and the forestay pulls the sail through the gap on a gybe. That is normally the lighter winds setup. Putting the sheet ahead of the sail is the heavy air (and more experienced sailor) setup. That allows the sail to completely invert ahead of the boat. The danger is you can run over your own sheet. Try it through the gap for the first few sets.
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
Old 05-21-2008
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Sailor
JohnRPollard has a spectacular aura aboutJohnRPollard has a spectacular aura about
If you are new to asymmetric spinnakers, you may wish to peruse this thread:
EDIT: Sorry folks, can't seem to make the link work. Trying again:
Nope, still doesn't work.
The thread is entitled "How to fly an asymmetrical spinnaker (or even spell it correctly)", posted by Pub911 on 1/16/2008. Should be able to find it with a search.
FINALLY, thanks to SailingDog:
LINKHow to fly an asymmetrical spinnaker (or even spell it correctly) - SailNet Community
Pacific Seacraft Crealock 31
Old 05-21-2008
sailhog's Avatar
sailhog sailhog is offline
sailhog has a spectacular aura aboutsailhog has a spectacular aura about
This month's Cruising World as a pretty extensive article on it as well.
Old 05-21-2008
JRP-
Make it a link but use your own text to link with... and use a word that the sailnet autolinking doesn't pick up, and convert the url using tinyurl.com.
LINK
Old 05-22-2008
vabuckeye's Avatar
vabuckeye vabuckeye is offline
vabuckeye will become famous soon enoughvabuckeye will become famous soon enough
I cannot let this die yet. I don't have a tack sleeve to attach my spinnaker tack too since I don't have a rolled furling. How do I attach this to the bow? I was going to try with a leader long enough to clear the railings and see how I faired. Or attach it directly to the bow? Not really ready to start flying the spinnaker yet as I am still learning the basics, but I have wondered on this most of the winter.
Jim
Display Modes
vB code is On
HTML code is Off
Refining Your Downwind Sails Brian Hancock Gear and Maintenance Articles 0 04-06-2004 08:00 PM
Sail Handling Brian Hancock Miscellaneous 0 12-04-2003 07:00 PM
Spinnaker Fundamentals Steve Colgate Learning to Sail Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Seamanship Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Racing Articles 0 06-24-2000 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
